-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   x33 qmobile white screen after flash (http://forum.gsmhosting.com/vbb/f296/x33-qmobile-white-screen-after-flash-2547786/)
pakmobiles 01-12-2019 14:46
x33 qmobile hung on logo after flash show white screen but hear starting sound.
Card found: S/N : 56B80985 , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 22 ]
Port Opened
Sync...
Initial Boot Failed!
Boot not done, reason : Wrong BootKeys
Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down )
Reconnect Power/Cable!
Set mode to : SP [SC773x] eMMC [Android 5.x]
3. Insert cable
Phone found! [ 22 ]
Port Opened
Sync...
3. Insert cable
Phone found! [ 16 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
3. Insert cable
Device boot not done
Check Drivers
Try again
3. Insert cable
Phone found! [ 16 ]
Open Port Failed!
3. Insert cable
Phone found! [ 22 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 22 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : QMobile_X33
Model Brand : QMobile
Model Device: QMobile_X33
AndrVersion : 6.0
BaseBand CPU: QMOBILE_X33
CompileDate : 7/24/2017 2:07:51 AM
Project Ver : MRA58K release-keys
Model Ext : QMobile X33
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:33
Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ]
3. Insert cable
Phone found! [ 22 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Prepare test data ...
Test flow #0 ...
Test flow passed!
Test flow #1 ...
Test flow passed!
Test flow #2 ...
Test flow passed!
Test flow #3 ...
Test flow passed!
Test flow #4 ...
Test flow passed!
Test flow #5 ...
Test flow passed!
Finalize Ok!
Test passed successfully!
Elapsed: 00:00:24
Loading : QMobile_X33_MP_V06_18_01_2017 by combinefile.com.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : QMobile_X33_MP_V06_18_01_2017
FastCheck : 0x009D5780B4
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : wnvitem.bin
File : wcnnvitem.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : userdata.img
File : logo.bmp
File : fbootlogo.bmp
File : cache.img
File : sysinfo.img
File : u-boot.bin
File : SC77xx.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : QMobile_X33_MP_V06_18_01_2017 by combinefile.com.pac
PacCPUinfo : SC77xx
File : fdl1.bin
File : fdl2.bin
File : wnvitem.bin
File : prodnv.img
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : userdata.img
File : logo.bmp
File : cache.img
File : sysinfo.img
File : u-boot.bin
3. Insert cable
Phone found! [ 22 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : wmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : wdsp.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : wcnmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : fbootlogo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : SYSINFO
Current File : sysinfo.img
Flashing now ...
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:04:03
DaKorId1122 05-11-2019 07:31
Same problem i have need solution please i flashed mp v06 and device have mp v07
YellowBoss 05-11-2019 08:02
In most this kind of fault is software/hardware incompatibility.
You have to use another firmware version that suit to your phone hardware.
shehryar khan 11-11-2019 15:34
Qmobile_X33_MP_V07_24_07_2017
100% working file
https://mega.nz/#!4fB0gazb!C2HgqM-b8...OMwWvQQibfSK64
Page generated in 0.19755 seconds with 5 queries
