05-06-2005, 11:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: UK
Member: 9732 Status: Offline Thanks Meter: 27 | X70 and COM port setting !!! My supplier advice me to use normal serial data cable with X70, and it works 100%, My question is that normal, do I have to use serial data cables with other models ? Please advice . BR KATOUE |
05-06-2005, 14:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Really, I don't know what can be with X70 cable supplied with Box. Maybe your X70 cable have defects ? As about other models. Don't need to use other serial data cables with Infinity, use cables that you have with Box. Also, for some operations (f.e. fast speed flashing) you can use only Infinity cables, because ordinary COM-port cables can't work good at high speed. B.R. InfinitySupport |
05-10-2005, 08:46 | #3 (permalink) |
Member: 9732 Status: Offline Thanks Meter: 27 | OK, after testing . I’ve discovered that if I plug X70 data cable (RJ45) with furious adapter (com to RJ45) , it works 100% regardless that using V9 will increase the risk factor, So some how I’ve got problem setting that box, Please advice. BR KATOUE |
05-10-2005, 09:14 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! If you use any other cable and this cable works, you can use it (not depends on voltage, even 9v cable power not increase any risk). Main thing: cable have to have external power in any case to avoid risk of power loss during unlock process. I can't understand why your cable not works with x70. Please, check this link: http://forum.gsmhosting.com/vbb/showthread.php?t=200078 it's about x300, but anyway, you can find some info about box/port settings. Also, did you tried to flash/unlock other models with Infinity ? Do you have cable problem only with x70 or with other models too ? B.R. InfinitySupport |
05-12-2005, 07:19 | #5 (permalink) |
Super Moderator Join Date: Aug 2000 Location: Malaysia
Member: 1922 Status: Offline Sonork: 100.64645 Thanks Meter: 692 | oops...i had this problem too...today i unlock 1pc of x70 v-A30 dun know why cant work in original pack cable but work in normal serial data cable.. **others model cable is working... |
05-12-2005, 08:08 | #7 (permalink) | |
Btw, what part of Unibox you have tried for X70 ? Left RJ-45 out is for USB-part input, and right RJ-45 out is for ordinary COM-port input. Also, F-BUS/M-BUS switch have to be in F-BUS position. B.R. InfinitySupport | |
E900 camera failed and com port problem | MC Harami | NSPRO | 0 | 03-09-2007 13:46 |
Adjusting Widcomm Com Port Settings | Mad Professor | Bluetooth-Software | 1 | 08-15-2006 20:38 |
how do i change my com port settings? | .:GSM International:. | NSPRO | 2 | 05-12-2005 22:22 |
I want tested schematic for read/write eeprom for N100 used Pony 2000 and COM port. | jarecki | VLSI, Conexant, Skyworks and Old Models | 1 | 06-22-2002 23:21 |
all25 com port setting | seven | x1x to x45/x50 | 0 | 02-04-2000 14:31 |
