Old 08-12-2005, 14:31   #1 (permalink)
Member: 138443
x70 dead
@Infinity Team,
My X70 died during unlocking and i was unable to get the log file so that i can send that log file to u. Now when i try to flash the phone its BOOT STATUS : NOT UPDATED .... it receives the ACK from the fone. but BOOT STUATUS IS STILL NOT UPDATED.
i m looking towards your reply.
with regards,
KSM1.
Old 08-12-2005, 18:40   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,219
Hello,
As I can understand, battery was already removed after unlock.
Flash phone using both options related with "boot". I think after this "BOOT STATUS" have to be updated and all have to be Ok.
But could you, pls, describe the initial problem ? What was happend with phone before ?
Old 08-13-2005, 11:10   #3 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
I also have same problem mybe i got the phone dead but could light from the key pads owner said he was tring to unlock it some software so i went dead but if you flash it it finish well but can not power on only the keypads can light what can i do?
Old 08-13-2005, 11:53   #4 (permalink)
Member: 130995
Hello,
If phone can be flashed but can't Power-On this can means that eeprom area is damaged.
Try to make this:
1. Flash CPK file
2. Try to make "Memory erase" with CB2000
3. Pls, post here info about phone that you can see in CB2000 after entering in test-mode (I mean SW Ver. Imei etc.)
4. Try to make unlock with our software. This operation will rebuild Lock area and maybe this can helps too.
Old 08-15-2005, 07:47   #5 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
Originally Posted by InfinitySupport
Hello,
Try to make this:
1. Flash CPK file
Hi Thanks were can i get the CB2000 software i dont have it and in case if i get it which cable to use?
Old 08-15-2005, 09:58   #6 (permalink)
Member: 130995
Hi,
Please, check "Panasonic" section in this forum.
Cable: the same as for unlock.
solution panasonic x70 dead GIGOLO Panasonic 5 07-31-2005 20:56
X70 Dead roddo Panasonic 5 10-30-2004 13:07
Panasonic X70 Dead During Flashing axilleask Panasonic 18 10-22-2004 19:30
X70 dead with griffin logger!!!!! reo Panasonic 8 10-17-2004 19:57
x70 dead after flashing teknotelgsm Panasonic 0 09-26-2004 18:37
Page generated in 0.29757 seconds with 8 queries
