Old 05-24-2008, 00:55   #1 (permalink)
tekirdaggsm's Avatar
Member: 106391
Thanks Meter: 37
Exclamation help : china n82 2sim pin out
org post:
http:///vbb/showth...08#post3338108
Originally Posted by tekirdaggsm View Post
hi guys i need pin out for infinitybox use J-TAG cable tx rx and gnd conneted but no read genaral information heLp me pLs very thanks
images :
Old 05-24-2008, 09:20   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
ou must use Rx_A and Tx_A test points
Old 05-24-2008, 12:28   #3 (permalink)
Member: 106391
Thanks Meter: 37
I've already treid to read phone with those, however i couldnt..
Any another ideas ?
Old 05-24-2008, 12:32   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please double check your wiring.
Tx_a goes to pin 3 of RJ45 (b0x)
Rx_a must go to pin 2 of Rj45 (box)
GND must go to pin 8 of rj45 (box port)
Old 05-24-2008, 14:39   #5 (permalink)
Member: 106391
Thanks Meter: 37
hello!
hi dear my cablo for infinity box connet to this right?
[img=http://img292.imageshack.us/img292/6039/tjagez1.th.jpg]
this photo t-jag for infinity box
Old 05-24-2008, 14:52   #6 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
yes Bro u have Made the cable Good ....
did u tried switching Rx and TX????
Old 05-24-2008, 15:06   #7 (permalink)
Member: 106391
Thanks Meter: 37
i now change rx and tx connet rx to tx tx to rx connet weLL done reading information aLL thans guys good job
Old 05-24-2008, 15:24   #8 (permalink)
Member: 106391
Thanks Meter: 37
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E03
Hardware version: EVEN25_HW
Software version: E558_JQ3F8.V60.01.1_
Software date: 2006.06.14
Barcode: E55803230001403
imei: 3525230*****
Finished, time used: 42 sec
Power off phone now !
Old 05-24-2008, 16:00   #9 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Connecting, wait...
imei: 3525230*****
Thts nice .. A Great Box
Old 05-24-2008, 16:30   #10 (permalink)
Member: 106391
Thanks Meter: 37
reading ok but not read and write second area heLp me pLs
Old 05-24-2008, 17:45   #11 (permalink)
Member: 106391
Thanks Meter: 37
nitialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
error: wrong answer: C3
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 22 sec
As you see box red the phone, but 2nd cpu area gave the error i wrote below.. Is it a common problem ? How can i make connection with 2nd area ??
Old 05-24-2008, 17:53   #12 (permalink)
Member: 39948
Thanks Meter: 68
nitialize...
Initialize Done
Set baud...
921600
Set baud Fail
bro please read the red line marked,
use lower speed.
Thanks
Old 05-24-2008, 20:31   #13 (permalink)
Member: 106391
Thanks Meter: 37
ty bro
and i am tried Low speed but and i see this error for 2nd area imei repair
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei repair" procedure again
If imei can't be detected:
1. make "complete" ffs format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei repair" procedure again
If imei can't be detected: read flash and send to support: [email protected]
heLp me pLs thanks
Old 05-25-2008, 07:08   #14 (permalink)
Member: 39948
Thanks Meter: 68
imei repair can be done with mode 3 on second cpu.
thanks
Old 05-26-2008, 12:37   #15 (permalink)
Member: 106391
Thanks Meter: 37
hey bro mode 3 and aLL prog normal done . but no change imei . no repair. no writing new imei why why why probLem infinity team HELM ME PLSSSSSSSSS
detecting eeprom/ffs size...
eeprom/ffs size: 00080000
ffs chip: 00
eeprom/ffs area: 00000000:00380000-003FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]]...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]_20080526-141627.B0E.bin
flash: EC257E25032501:2AEA0000000000
Backup required data Done
Patch required data...
4 step(s) required to finalize
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Finished, time used: 102 sec
Remove/Install battery now !
New china 1112,1600 pin out Shantobhai Chinese Models & Cloned Phones 24 07-22-2010 06:43
Solution : HOW TO FIND PIN OUT in SPD CPU bestncheap VE-KING 21 01-02-2009 20:27
6300 china phone rm243 pin out please help ailman_78 Infinity-Box 1 10-10-2008 16:32
China N95 New pin out here!!! .::skybird::. Chinese Models & Cloned Phones 1 09-08-2008 09:34
pls give me a n98(rh37) 2sim pin out nishantha Infinity-Box 1 03-07-2008 13:59
Page generated in 0.29376 seconds with 9 queries
