09-08-2005, 11:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2005
Member: 163076 Status: Offline Thanks Meter: 97 | X70 Dead during unlocking i was unlocking Panasonic x70 with infinity box and here is the error message and fone is dead now any suggestions Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3131040219 FLASH-ID: 89000D88 Parameters Done Check data... STEP-01 in progress... Check data Done Check HW... FLASH supported[89000D88] 1. REMOVE BATTERY NOW ! 2. Install battery 3. Press "Ok" button 4. Power-On phone after instruction Device have to be SWITCHED OFF Press Power button now... Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3/1... SW Version: GAX70A3131040219 FLASH-ID: 89000D88 Action-3/2... Err: write2: 00000000 Err: write2: 00000000 Action-3 Failed[] Operation Failed Finished WBR... |
09-08-2005, 12:42 | #3 (permalink) |
Member: 163076 Status: Offline Thanks Meter: 97 | X70 Still Same Problem..... I tried again but fone is still dead. message is as under: Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: Unknown FLASH-ID: 89000D88 Parameters Done Check data... STEP-02 in progress... Check data Done Check HW... FLASH supported[89000D88] Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3 Ok FLASH-ID: 89000D88 Action-4 Ok Action-5 Ok Action-6 Ok STEP-2 complete ! Operation Done Process completed Phone Unlocked Ok ! Remove/Install battery now ! Finished Any More Suggestions WBR. |
09-09-2005, 11:25 | #6 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Quote:
i have a idea but not sure..just try to do...i think u have cb2000.just try to connect the phone with cb2000 & if it can goes into test mode then read the phone info & after that try to power on the phone by click on "Normal mode" or "soft-sim" command button of cb2000.i hope it can be power on ur phone.best of luck. proxy_gsm | |
09-09-2005, 19:01 | #8 (permalink) | |
Pls, explain more detailed what's happen. Also, pls, include info from Log_X70.txt file. | |
09-09-2005, 19:06 | #9 (permalink) | |
1. Start Winmodo 2. Menu Option -> Boot download: Checked 3. Menu Option -> Smart boot update: Checked 4. Menu Settings -> COM port: select COM port 5. Menu Settings -> Baud Rate: select 115200 6. "CUST" area: Red 7. "LP" area: Red 8. "CODE" area: Green 9. Press "Browse" button and select flash file 10. Connect cable to PC 11. Connect cable to phone 12. Press "Start Download" button 13. Shortly press phone power button | |
09-09-2005, 21:48 | #10 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
I think you should pls start work on boot redirection as you did on the G60 or maybe a jtag solution to dead panasonic phones,....it ll be another big PLUS for this great box.. bR | |
09-10-2005, 15:49 | #11 (permalink) |
Member: 163076 Status: Offline Thanks Meter: 97 | Panasonic X70 Alive Again.... I FULLY CHARGED BATTERY First 1. Start Winmodo 2. Menu Option -> Gang Mode: Checked 3. Menu Option -> Boot Download: Checked 3. Menu Option -> Smart boot update: Checked 4. Menu Option -> Completion Beep: Checked 5. Menu Settings -> COM port: select COM1 6. Menu Settings -> Baud Rate: select 19200 7. "CUST" area: Red 8. "LP" area: Red 9. "CODE" area: Green 10. Press "Browse" button and select flash file XA70DA39.rff 11. Connect cable to PC 12. Connect cable to phone 13. Press "Start Download" button ** 14. Shortly press phone power button the main thing is i selected baud rate 19200 and it took 88 Mins and never pressed Phone Power Button. But With luck my x70 is alive again. thans 2 INFINITYSUPPORT and thanx 2 GSMHOSTING Forum But the sad thing is i forgot 2 save the log file any way i will never repeat this again. WBR.. |
09-10-2005, 19:31 | #12 (permalink) |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Congrats Congrats Gr8sightman u were lucky but don't ever forget to upload log file again but i think u were over joyed thats y you forgot to save Log file isn't it? any ways kool sound u have solved such prob BR. |
X70 Dead During Unlock. | ejazkhan9 | Infinity-Box | 2 | 05-26-2008 13:15 |
X70 dead during unlock | Irfangk786 | Infinity-Box | 18 | 02-13-2008 14:02 |
X70 dead during unlock. | Mr GsM | Infinity-Box | 2 | 06-17-2006 11:56 |
Panasonic X70 Dead During Flashing | axilleask | Panasonic | 18 | 10-22-2004 19:30 |
help !!! t68 dead during unlock with terminator | essojay | Sony Ericsson | 5 | 01-08-2003 18:15 |
