x70 questions .. hi, 1.) one my custommer have problem with X70 he have dead x70 he can unlock with infinity , but cannt flash (cannt flash with winmodo too) phone is dead (it was dead before unlock) phone can communicate 2.) and second x70 : somebody have flash it after flash winmodo dont calculate CRC now phone is dead any idea ? pyroz |
1. Pls, send us Log file after unlock with Infinity, we will check it. Also, tell me, pls, exactly: what is the error when he tried to flash with Winmodo ? 2. We don't have solution for this. B.R. InfinitySupport |
Log opened: [27.5.2005] [16:04:29] App: D:\Program Files\InfinityBox\Pana\X70_v105.exe Current device: X70 S/N: 00B7:0103 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3232040408 FLASH-ID: 10107E7E Parameters Done Check data... STEP-01 in progress... Check data Done Check HW... FLASH supported[10107E7E] Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3/1... SW Version: GAX70A3232040408 FLASH-ID: 10107E7E Action-3 Ok STEP-1 complete ! Operation Done First part completed Remove/Install battery and press "Unlock" button again. Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3232040408 FLASH-ID: 10107E7E Parameters Done Check data... STEP-02 in progress... Check data Done Check HW... FLASH supported[10107E7E] Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3 Ok FLASH-ID: 10107E7E Action-4 Ok Action-5 Ok Action-6 Ok STEP-2 complete ! Operation Done Process completed Phone Unlocked Ok ! Remove/Install battery now ! Finished |
Hello, Im sure now - phone can be flashed with Winmodo w/o problem. At least Winmodo have to detect phone and start flashing process. Pls, tell me what is wrong when you try to flash phone with Winmodo (if it will be errors in Winmodo, pls, send me screenshot with error). Pls, be sure that correct COM port selected in Winmodo. I think you need to flash phone (at least CPK file). Then you can try to make "Memory Erase" with CB2000. B.R. InfinitySupport |
or try to check batt voltage before flashing! looks like empty battery. |
winmodo and cb2000 dont detect phone , battery is full only infinity can detect and do unlock any idea ???? pyroz |
damaged eeprom like in oldest phones that enter in testmode but not powered on. but anyway strange- why standart flasher can`t connect it? |
If Infinity-Box can connect to phone for Unlock, then it's 100% possible to flash phone with Winmodo. Do you use the same cables for Unlock and for Winmodo flashing try ? B.R. InfinitySupport |
winmodo have wrote "signaling" but cannt connect phone ! only infinity can see this phone on unlock procedure any idea ??? pyroz |
Check your com, make sure it's the same as infinity-box. Like Infinity-support said, if the box can detect it, winmodo must also work. The Beast |
man, all this I have checked ! winmodo cant see it but infinity can unlock ... its all pyroz |
did u press power button Quote:
when it says signaling do u press powr butoon if u dont then do it WBR |
