Old 07-17-2005, 23:13   #1 (permalink)
Member: 7810
Thanks Meter: 4
x70 questions ..
hi,
1.) one my custommer have problem with X70
he have dead x70
he can unlock with infinity , but cannt flash (cannt flash with winmodo too)
phone is dead (it was dead before unlock)
phone can communicate
2.) and second x70 : somebody have flash it
after flash winmodo dont calculate CRC
now phone is dead
any idea ?
pyroz
Old 07-18-2005, 07:35   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by pyroz
hi,
he have dead x70
now phone is dead
any idea ?
pyroz
Hello,
1. Pls, send us Log file after unlock with Infinity, we will check it.
Also, tell me, pls, exactly: what is the error when he tried to flash with Winmodo ?
2. We don't have solution for this.
B.R.
InfinitySupport
Old 07-18-2005, 15:46   #3 (permalink)
Member: 7810
Thanks Meter: 4
Log opened: [27.5.2005] [16:04:29]
App: D:\Program Files\InfinityBox\Pana\X70_v105.exe
Current device: X70
S/N: 00B7:0103
Loading, wait...
Ready
Checking data, wait...
Device have to be SWITCHED OFF
Press Power button now...
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
SW Version: GAX70A3232040408
FLASH-ID: 10107E7E
Parameters Done
Check data...
STEP-01 in progress...
Check data Done
Check HW...
FLASH supported[10107E7E]
Check HW Done
Operation...
Working, don't interrupt...
Action-1 Ok
Action-2 Ok
Action-3/1...
FLASH-ID: 10107E7E
Action-3 Ok
STEP-1 complete !
Operation Done
First part completed
Remove/Install battery and press "Unlock" button again.
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
FLASH-ID: 10107E7E
Parameters Done
Check data...
STEP-02 in progress...
Check data Done
Check HW...
Check HW Done
Operation...
Action-1 Ok
Action-2 Ok
Action-3 Ok
FLASH-ID: 10107E7E
Action-4 Ok
Action-5 Ok
Action-6 Ok
STEP-2 complete !
Operation Done
Process completed
Phone Unlocked Ok !
Remove/Install battery now !
Finished
Old 07-18-2005, 16:04   #4 (permalink)
Member: 130995
Hello,
Im sure now - phone can be flashed with Winmodo w/o problem.
At least Winmodo have to detect phone and start flashing process.
Pls, tell me what is wrong when you try to flash phone with Winmodo (if it will be errors in Winmodo, pls, send me screenshot with error).
Pls, be sure that correct COM port selected in Winmodo.
I think you need to flash phone (at least CPK file). Then you can try to make "Memory Erase" with CB2000.
B.R.
InfinitySupport
Old 07-18-2005, 16:43   #5 (permalink)
balu_dark's Avatar
Member: 16251
Thanks Meter: 38
or try to check batt voltage before flashing! looks like empty battery.
Old 07-19-2005, 21:43   #6 (permalink)
Member: 7810
Thanks Meter: 4
winmodo and cb2000 dont detect phone , battery is full
only infinity can detect and do unlock
any idea ????
pyroz
Old 07-20-2005, 08:31   #7 (permalink)
balu_dark's Avatar
Member: 16251
Thanks Meter: 38
damaged eeprom like in oldest phones that enter in testmode but not powered on.
but anyway strange- why standart flasher can`t connect it?
Old 07-20-2005, 10:25   #8 (permalink)
Member: 130995
any idea ????
pyroz
Hello,
If Infinity-Box can connect to phone for Unlock, then it's 100% possible to flash phone with Winmodo.
Do you use the same cables for Unlock and for Winmodo flashing try ?
B.R.
InfinitySupport
Old 07-20-2005, 10:46   #9 (permalink)
Member: 7810
Thanks Meter: 4
winmodo have wrote "signaling" but cannt connect phone ! only infinity can see this phone on unlock procedure
any idea ???
pyroz
Old 07-20-2005, 19:17   #10 (permalink)
Member: 61620
Thanks Meter: 5
Check your com, make sure it's the same as infinity-box.
Like Infinity-support said, if the box can detect it, winmodo must also work.
The Beast
Old 07-20-2005, 21:37   #11 (permalink)
Member: 7810
Thanks Meter: 4
man, all this I have checked ! winmodo cant see it but infinity can unlock ... its all
pyroz
Old 06-07-2006, 09:15   #12 (permalink)
Gr8SightMan's Avatar
Member: 163076
Thanks Meter: 97
did u press power button
any idea ???
pyroz
Hi
when it says signaling do u press powr butoon
if u dont then do it
WBR
question about superdongle data of n-95 8gb compue Universalbox 2 03-29-2010 15:16
One Question About Cruiser,pls Gubby_J Cruiser Suite 2 03-29-2010 12:46
X70 Call RejectedHi infinity team i have 2 panasonic X70 one is when i making a call Nasmi Infinity-Box 13 11-18-2005 00:18
Question about F0.13.14 tamper alert question mr_x4you Motorola Old Legacy (EMMI) 0 02-26-2003 08:38
Page generated in 0.18526 seconds with 9 queries
