X70 restart problem after unlock I unlocked a X70 with Infinitybox. but the customer is complaining that they phone restarts after about two minutes. anyone know about this problem ? |
Hi, I don't think that it's "after-unlock" problem. Pls, download CB2000 (you can find it in "Panasonic" section) and make "Memory erase" function. Also, if no results, it will be good to flash phone with CPK file (customization file). I can't guarantee that this helps for sure, but we have reason to try. B.R. InfinitySupport |
after "Memory erase" function through CB2000 solve this type of problem |
Where can I find the memory erase in CB 2000 ? |
Sometimes it's possible to find some answers in "FAQ" thread: http://forum.gsmhosting.com/vbb/showthread.php?t=207207 How to use CB2000: http://forum.gsmhosting.com/vbb/showthread.php?t=220184 |
Need help fast. I have done the memory erase.... seen MMI default passed after pressing memory erase on CB2000 Put phone on Vibrate and phone restarts when a call is made to it. I have unlocked the phone again and done the memory erase and the problem is the same.... can you explain more on flashing phone with CPK file ? only see unlock tab in V1.05 A. Where to flash with CPK file .... |
Hi, Use winmodo and original firmwares. You can find X70 firmware here: http://vts.vlad.ru/~gsm/Panasonic/Firmware/X70/ |
things have taken a turn for the worst... The phone is not turning on consistently now....just blinks when you hold the power button long enough.. it is not connecting to either CB2000 or when trying to flash with Winmodo, it justs says signalling..and nothing hapens after I press the power button.. the battery is fairly low, and it does not seem to be charging, the charging light is blinking but the phone only blinks when trying to turn on with the charger... and after over an how the battery is still low.. the customer is now angry as the phone is now in a worse state... it hardly turns on, and when it does it only blinks... Why is this ?. I need something to tell the customer ?...is this a problem caused by the unlocking or is it a problem with the X70 phones ? |
Hi, I think it's time to check phone hardware. |
hard to tell my customer that... they carried it to me powering on fully after first unlock and return to them, the carried back complaining of restarting now it only blinks after another unlock.... seems like I should be looking to pay the customer for the phone... |
after blinking show , chek ur battery voltage if battery voltage show full than try clean jeck and than flashing after flashing it will solve it this problem not in hardware |
