Old 07-04-2005, 14:29   #1 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
X70 restart problem after unlock
I unlocked a X70 with Infinitybox. but the customer is complaining that they phone restarts after about two minutes. anyone know about this problem ?
Old 07-04-2005, 15:38   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
I don't think that it's "after-unlock" problem.
Pls, download CB2000 (you can find it in "Panasonic" section) and make "Memory erase" function.
Also, if no results, it will be good to flash phone with CPK file (customization file).
I can't guarantee that this helps for sure, but we have reason to try.
B.R.
InfinitySupport
Old 07-04-2005, 16:10   #3 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
after "Memory erase" function through CB2000 solve this type of problem
Old 09-08-2005, 04:59   #4 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Where can I find the memory erase in CB 2000 ?
Old 09-08-2005, 08:38   #5 (permalink)
Member: 130995
Hi,
Sometimes it's possible to find some answers in "FAQ" thread:
http://forum.gsmhosting.com/vbb/showthread.php?t=207207
How to use CB2000:
http://forum.gsmhosting.com/vbb/showthread.php?t=220184
Old 09-11-2005, 14:34   #6 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Originally Posted by InfinitySupport
Hi,
B.R.
InfinitySupport
Need help fast.
I have done the memory erase.... seen MMI default passed after pressing memory erase on CB2000
Put phone on Vibrate and phone restarts when a call is made to it.
I have unlocked the phone again and done the memory erase and the problem is the same....
can you explain more on flashing phone with CPK file ?
only see unlock tab in V1.05 A. Where to flash with CPK file ....
Old 09-12-2005, 08:43   #7 (permalink)
Member: 130995
Hi,
Use winmodo and original firmwares.
You can find X70 firmware here:
http://vts.vlad.ru/~gsm/Panasonic/Firmware/X70/
Old 09-12-2005, 22:07   #8 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
things have taken a turn for the worst...
The phone is not turning on consistently now....just blinks when you hold the power button long enough..
it is not connecting to either CB2000 or when trying to flash with Winmodo, it justs says signalling..and nothing hapens after I press the power button..
the battery is fairly low, and it does not seem to be charging, the charging light is blinking but the phone only blinks when trying to turn on with the charger... and after over an how the battery is still low..
the customer is now angry as the phone is now in a worse state... it hardly turns on, and when it does it only blinks...
Why is this ?. I need something to tell the customer ?...is this a problem caused by the unlocking or is it a problem with the X70 phones ?
Old 09-13-2005, 16:51   #9 (permalink)
Member: 130995
Hi,
I think it's time to check phone hardware.
Old 09-13-2005, 19:37   #10 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
hard to tell my customer that...
they carried it to me powering on fully
after first unlock and return to them, the carried back complaining of restarting
now it only blinks after another unlock....
seems like I should be looking to pay the customer for the phone...
Old 09-14-2005, 08:42   #11 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
after blinking show , chek ur battery voltage
if battery voltage show full than try clean jeck and than flashing
after flashing it will solve it
this problem not in hardware
P910 restart problem after UNLOCK MSL .:==di@bila==:. UST Pro II 3 07-12-2007 17:44
6680 -restart problem after unlock! Supermen! Nokia Base Band 5 ( BB-5 ) 2 05-15-2007 11:19
P910i restart problem after unlock by using create secrity area. JOEY.CN Cruiser Suite 0 06-05-2006 15:21
X70 strange problems after unlock chrisonic Infinity-Box 2 01-03-2006 21:13
Panasonic X70 camera problem after unlock? DanV Panasonic 2 06-30-2004 13:34
Page generated in 0.20446 seconds with 9 queries
