05-14-2005, 15:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Just look into Panasonic section in this forum. You can fiund many links to x70 flash files (for Winmodo) with different LP. B.R. InfinitySupport |
05-14-2005, 16:44 | #3 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | x70 russian HI, Thanks for the reply, but i only have Infinity Box no other cables, only what came with the box. Can i flash it with the Infinity Box or do i need another cable? Many Thanks James |
05-14-2005, 17:15 | #4 (permalink) | |
Yes, you can use Infinity-Box cables for X70 flashing. Use the same cable that you use for x70 unlock. Use original Winmodo (you can find this soft in our support area). Also, with Infinity-Box hardware you can flash X70 at high speed (406250 or 812500 instead of ordinary 115200 baud). But use this fast-flashing speed carefully. It is not danger way if you want to write only LP in phone, but it can be dangerous if you write firmware with BOOT code. B.R. InfinitySupport | |
Please help *** th4 language pack with russian language for vygis please | morzh | BF, BG, TH, BHx Series | 1 | 09-04-2005 15:14 |
X70 hungarian language | jokers5 | Panasonic | 0 | 05-04-2005 21:58 |
X70 Fast Language Flash !! | UFoTeaM | UfoTools | 13 | 12-14-2004 19:52 |
wanted panasonic G60 & X70 Russian flasher | Mobile Lab | Wanted Products | 0 | 01-17-2004 23:06 |
Need 511 Russian language file & language flasher | dennt | BF, BG, TH, BHx Series | 2 | 04-11-2002 18:57 |
