X70 unlock problem Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3939041214 FLASH-ID: 10107E7E Parameters Done Check data... STEP-01 in progress... Check data Done Check HW... FLASH supported[10107E7E] Check HW Done Operation... Working, don't interrupt... Action-1 Failed[] Operation Failed Finished i need help |
same pro here m8 i hope infinity team can reply asp Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished i will keep on trying with this untill someting happen. |
What is with phone now ? Can it power-on or connect to software ? |
Could you try to connect phone on other baud rate ? |
problem solved on another pc |
What is this phone history ? Is it was only one unlock attempt (your log posted here before) or it was other attempts ? If it's not first, give me, pls, previous logs. |
Log opened: [02/10/2005] [15:58:35] App: C:\Program Files\InfinityBox\X70\X70_v105.exe Current device: X70 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished ---------------- Log opened: [02/10/2005] [16:04:47] App: C:\Program Files\InfinityBox\X70\X70_v105.exe Current device: X70 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished ---------------- Log opened: [02/10/2005] [16:43:56] App: C:\Program Files\InfinityBox\X70\X70_v105.exe Current device: X70 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished ---------------- Log opened: [02/10/2005] [16:52:40] App: C:\Program Files\InfinityBox\X70\X70_v105.exe Current device: X70 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished ---------------- Log opened: [02/10/2005] [16:58:46] App: C:\Program Files\InfinityBox\X70\X70_v105.exe Current device: X70 Loading, wait... Ready Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... Err: can't enter TestMode Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished Checking data, wait... Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... Parameters Failed Finished thanks for ur help. |
