Old 06-23-2007, 00:43   #1 (permalink)
Member: 193747
X70 unlock problem
Hello Infinity Support,
I've had a problem with the X70's. The first one was a couple of weeks ago which gave a 'write error' message at stage 3 - I aborted the unlock - the phone powered up no problem and I returned it to the cucstomer. The second was the same 'write error' message at stage 3 - I decided to press retry - the error just came up again so I decided to pres 'ignore' which I did a further 5 times. The result was a dead phone. I'm sorry but I didn't save the logs but the last one looked identical to the othe member who had this problem. I've read all the threads and tried to flash it various ways but it gets no further than 'echanging parameters' or something similar.
Anyway I have another one here to unlock and wondered if you could load an old version of the software (if it is as easy as that) - as I never had a problems in the past. The one I have on hand is a sure thing a good old A31 but I'll await your response before I attempt anything. Any assistance would be appreciated please. Thank you.
Regards, WW.
Old 06-23-2007, 01:09   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Please, be sure that your cable is Ok, clean phone connector contacts before operation and follow instruction step-by step.
I can't give any other advice.
Old 06-23-2007, 14:29   #3 (permalink)
Member: 193747
Hello,
I've double checked the connections and pinout and all are fine (it's the same cable I've used to unlock numerous X70's in the past). It may just be a coincidense but it seems to be the same problem others are facing:
X70 dead during unlock
Panasonic X70 dead while unlock
X70 flashing problem
x70 dead please help
Panasonic X70 Dead try to Unlock
x70 wont unlock 2nd post
As I say above it's been a while since I've had any of these models to unlock so it seems a bit strange that I'm now having a problem where there wasn't a problem before. If you can let me know if there's been no update for the X70 software in the last 12 months, then I'll try a clean install. I'm not trying to blame Infinity here, it's without doubt the best box on the market but if there's a bug then hopefully we can work together to get it sorted. Yes I understand the X70 is an old model but the last thing anyone wants to do is say to a customer 'I can't do that model' or ' whoops your phone dont work any more'.
I'll try to unlock this one I have ( ver. A31) and post the result. I'm probably wrong but I personally don't think it's a cable/connection problem as the software seems to be communicating with the phone until the 'write error'.
Thanks anyway.
Regards, WW.
Old 06-23-2007, 20:46   #4 (permalink)
Member: 193747
This one wouldn't connect for some reason, I think I tried everything twice reduced the baud rate, double checked the com etc - I uninstalled and reinstalled the box drivers, set the baud to 19200 - it connected, Infinity did it's magic and everything went ok - unlocked no problem.
Who knows what the problem was with th other 2? Maybe the phones had already been corrupted by some-one before they were brought to me?
Log opened: [23/06/2007] [17:20:57]
App: D:\Program Files\InfinityBox\Pana06\X70.exe
Current device: X70
S/N:
Loading, wait...
Ready
Checking data, wait...
Device have to be SWITCHED OFF
Press Power button now...
Err: can't enter TestMode
Finished
Finished
Finished
Finished
Log opened: [23/06/2007] [17:26:14]
Current device: X70
S/N:
Loading, wait...
Ready
Finished
Log opened: [23/06/2007] [17:29:28]
Current device: X70
S/N:
Loading, wait...
Ready
Finished
Finished
Finished
Finished
Err: COM7
Finished
Err: COM7
Finished
Err: COM6
Finished
Finished
Finished
Finished
Log opened: [23/06/2007] [17:43:32]
Current device: X70
S/N:
Loading, wait...
Ready
Finished
Finished
Log opened: [23/06/2007] [17:52:56]
Current device: X70
S/N:
Loading, wait...
Ready
Finished
Log opened: [23/06/2007] [17:54:20]
Current device: X70
S/N:
Loading, wait...
Ready
Finished
Finished
Log opened: [23/06/2007] [18:13:58]
Current device: X70
S/N:
Loading, wait...
Ready
Finished
Finished
Finished
Finished
Err: COM1
Finished
Err: COM1
Finished
Err: COM2
Finished
Err: COM2
Finished
Finished
Err: COM4
Finished
Err: COM4
Finished
Err: COM6
Finished
Err: COM6
Finished
Err: COM7
Finished
Err: COM7
Finished
Err: COM8
Finished
Err: COM8
Finished
Err: COM9
Finished
Err: COM9
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
SW Version: GAX70A3131040219
FLASH-ID: 89000D88
Parameters Done
Check data...
STEP-01 in progress...
Check data Done
Check HW...
FLASH supported[89000D88]
1. REMOVE BATTERY NOW !
2. Install battery
3. Press "Ok" button
4. Power-On phone after instruction
Check HW Done
Operation...
Working, don't interrupt...
Action-1 Ok
Action-2 Ok
Action-3/1...
FLASH-ID: 89000D88
Action-3/2...
Action-3 Ok
STEP-1 complete !
Operation Done
First part completed
Remove/Install battery and press "Unlock" button again.
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
FLASH-ID: 89000D88
Parameters Done
Check data...
STEP-02 in progress...
Check data Done
Check HW...
Check HW Done
Operation...
Action-1 Ok
Action-2 Ok
Action-3 Ok
FLASH-ID: 89000D88
Action-4 Ok
Action-5 Ok
Action-6 Ok
STEP-2 complete !
Operation Done
Process completed
Phone Unlocked Ok !
Remove/Install battery now !
Finished
Old 06-24-2007, 20:52   #5 (permalink)
Member: 130995
Hello,
it's really hard to say what was the problem with previous 2 units. To be honest I have no any good idea.
Panasonic X70 Unlocking Problems axilleask Griffin 3 11-18-2004 11:45
x70 unlocking problem Moosani Griffin 15 11-09-2004 08:50
x70 unlock problem dimon Griffin 2 10-21-2004 23:12
x70 unlock problem e_mobile Griffin 9 09-25-2004 04:42
Panasonic X70 unlock Problem kwh Griffin 11 06-02-2004 00:27
Page generated in 0.31705 seconds with 8 queries
