X700 unlock problem i try to unlock x700 keeps on giving me error... now the phone having start up problem pls hep me... i try this go to "Pana01" folder copy file falcon_eep129.cfg to falcon_eep65535.cfg try to make unlock again but i cannot find this falcon_eep65535.cfg file...im using pana 01 v1.51 pls help me... COM5 selected Device: Panasonic-X700,X701 Checking data, wait... Action: TestMode On Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... boot answer: 02 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0089:8862 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\Panasonic-X700,X701_eeprom-sta_20081021-130048.30E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\falcon_eep65535.cfg error: can't load database v.65535 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\Panasonic-X700,X701_eeprom-sec_20081021-130051.30E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\Panasonic-X700,X701_eeprom-complete_20081021-130111.30E.bin backup critical area Done Check memory... loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\falcon_eep65535.cfg error: can't load database v.65535 error: operation terminated. Probably unsupported eeprom structure. Please, contact to Support and attach last created backup file in bug-report. Check memory Failed Finished, Remove/Install battery now ! Time used: 38 sec |
Hello, As I can see phone has damaged eeprom. Use repair eeprom from support area and try again. |
