Old 07-01-2016, 12:12   #1 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 128
x900 invalid sim
plz plz plz i do all but same x900 after format with other tool.now invalid sim
read from ok set bin file scatore file nv file repair baseband but nothing change
Card found : S/N : 3F39398A , v0130
Chinese Miracle II [MTK module] v 1.51
Start at : [6/30/2016 / 9:41:21 PM]
Operation : Write NVRAM [ v1.51 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4838473264040502A26952A1CD
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040502A26952A1CD
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x476F0D984065F8B3BB337AC0C2D5E888
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[NVCheck] : BBID : MT6592 , NVID : MT6592
[NVM] : Write Ok!
[Info] : NVRAM Repair on erased/damaged phone :
1. Fix Unknown BaseBand
2. Power On phone, check BB state
3. Write NVRAM
4. Repair Security
Done!
Elapsed: 00:00:22
Start at : [6/30/2016 / 11:32:48 PM]
Operation : Format FileSystem [ v1.51 ]
Wait for phone...
Phone found! [ 80 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:22
Reconnect Power/Cable!
Finish at : [6/30/2016 / 11:33:10 PM]
Start at : [6/30/2016 / 11:36:50 PM]
Operation : Fix Unknown BaseBand [ v1.51 ]
User accepted FixBB operation!
Wait for phone...
Phone found! [ 80 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Step #1
Step #1 ... Ok
Step #2
Step #2 ... Ok
Step #3
Step #3 ... Ok
Reset Done!
Done!
Elapsed: 00:00:32
Finish at : [6/30/2016 / 11:37:23 PM]
Start at : [6/30/2016 / 11:42:19 PM]
Operation : Repair Security [ v1.51 ]
Wait for phone...
Phone found! [ 80 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 355254785586656
Set IMEI [01] : 355254785587456
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 80 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:43
Operation : Flash [ v1.51 ]
======= Flash
Files set for flashing :
[ MCU ] : MT6592__QMOBILE__QMobile_X900__QMobile__QMobileX90 0_MP_LOW_2014_1104__Android_4.4.2.ispff
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : QMobile X900
ProdModel : QMobile X900
Device : QMobile
AndroidVer: 4.4.2
MTKxCPU : MT6592
MTKxPRJ : QMobileX900_MP_LOW_2014_1104
ISPFF ID : 6592 , TARGET ID : 6592
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write done , 7456 blocks sent
Done!
Elapsed: 00:15:09
Old 07-01-2016, 13:55   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,616
Hello,
What is status of BaseBand?
Try to use Fix DL Mode/Repair ExtData, in rare cases it helps.
If nothing works then make BPLGUI file under Extra-Repair tab and repair ime1 with MauiMeta tool.
Br.
Infinity Box Support Team.
Old 07-02-2016, 11:20   #3 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 128
Operation : Fix Android Partitions [ v1.51 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Refill : Cache
Refill Ok!
Refill : UserData
Refill Ok!
Done!
Elapsed: 00:00:24
Operation : Fix DL Errors [ v1.51 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
DA DLFix Passed!
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 357607060070720
IMEI [01] : 357607065070725
Set IMEI [00] : 352548558745875
Set IMEI [01] : 352547855879858
Wait for phone...
Phone found! [ 18 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:42
all done but same and
mauimeta tool canot detect with target
Old 07-02-2016, 12:27   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 13,765
After working dump mobile must be OK.
If you even can't connect it in meta - probably, there is HW fault.
Old 07-03-2016, 04:51   #5 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 128
set condition after formate with other tool .its hw?
Page generated in 0.24763 seconds with 7 queries
