01-06-2011, 14:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Manchester, UK
Member: 180873 Status: Offline Thanks Meter: 80 | X991 flashing problem 0 nvram_sec.c, 657, 19192 19447 0 Code: ==== [06/01/2011 12:53:05] ==== COM25 [VCP0] selected module v3.71 Device: ZTE-X991 Checking data, wait... Action: write flash NAND write: Firmware ZTE-X991_ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X991_V1_Z2_FRES_D18F109_2010-04-06_Orange-Rio_En_Fr_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... done firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X991_V1_Z2_FRES_D18F1 nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: X991_V1_Z2_FRES_D1EF114 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X991_V1_Z2_FRES_D1EF1 nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X991_V1_Z2_FRES_D1EF114.BIN project-id: X991_V1_Z2_FRES_D1EF114, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.71, database date: 23.12.2010): ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X991_V1_Z2_FRES_D1EF114.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X991_V1_Z2_FRES_D18F1 nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 40 min 10 sec Remove/Install battery now ! |
02-18-2011, 11:27 | #3 (permalink) |
Member: 180873 Status: Offline Thanks Meter: 80 | I flashed another one and i have the same error as in first post, tried flashing several times but still the phone is showing the same error, what can i do? |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
