03-02-2017, 07:01 | #1 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Xiaomi HM NOTE 1LTE MSM8226 READ FW Done 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 0840B50C ID_BLOCK_I : 009180E1 ID_BLOCK_L : 996B01FD58C6F3FEA99E765F98E3735B ID_BLOCK_L : 1B6AD47778EB53D0F5C0954240AFB982 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Xiaomi ProdName : dior ProdModel : HM NOTE 1LTE Device : dior AndroidVer: 4.4.2 Manufact. : Xiaomi QLMxCPU : MSM8226 DevInfo : MSM8226__Xiaomi__Xiaomi__ANDR_v4.4.2__HM_NOTE_1LTE __dior__dior Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : NON-HLOS.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x26 / eMMC Firmware Size : 896 MiB Done! Elapsed: 00:02:40 |
The Following 3 Users Say Thank You to buffer2k11 For This Useful Post: |
03-06-2017, 15:52 | #3 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi sir, Need this file urgent Please upload . I have too readed but irs with Virus. Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 0716470A ID_BLOCK_I : 009180E1 ID_BLOCK_L : 9F6903FB5AC0CDF8A79C7459A6FD7555 ID_BLOCK_L : CD800EA1923DAD26DB1A7FB4BE716F6C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 0716470A ID_BLOCK_I : 009180E1 ID_BLOCK_L : 9F6903FB5AC0CDF8A79C7459A6FD7555 ID_BLOCK_L : CD800EA1923DAD26DB1A7FB4BE716F6C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Xiaomi ProdName : dior ProdModel : HM NOTE 1LTE Device : dior AndroidVer: 4.4.2 Manufact. : Xiaomi QLMxCPU : MSM8226 DevInfo : MSM8226__Xiaomi__Xiaomi__ANDR_v4.4.2__HM_NOTE_1LTE __dior__dior Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : NON-HLOS.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x26 / eMMC Firmware Size : 896 MiB Done! Elapsed: 00:01:59 Reconnect Power/Cable! Please need file. Thanks Br, Raja |
