Old 11-02-2016, 10:50   #1 (permalink)
Member: 1086393
Thanks Meter: 771
Xiaomi MI note 4 can't flash!
Hi,
I want to flash mi note 4 to global rom, but cm2 fail to flash.
Scatter Load Ok , BaseBand : MT6797 , Project : nikel , Storage : EMMC
Files found : 18 , Set to Flash : 17
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 137 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6797
BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , R4BNJ
[eMMC] : FLASH_CID : 150100434A4E42345207D2DEEE6F738D
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID    : 0xF8645C380D279F5E66C6B783F514BC8C
INT RAM    : 0x00000000
EXT RAM    : 0xC0000000 [3 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6797 , Project : nikel , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
M67BL : Check eMMC compatibility
BL : Undefined structure, determined as forced
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000001A80000
Erase : 0x0000000002288000-0x0000000004000000
Erase : 0x0000000007800000-0x0000000000A00000
Erase : 0x0000000008500000-0x0000000002600000
Erase : 0x000000000B000000-0x00000001BE800000
Flash Erase Done, time used : 00:00:02
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Failed!
Something wrong with files or connection!
Operation Failed
Elapsed: 00:00:23
Reconnect Power/Cable!
Old 11-02-2016, 10:59   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
You read FW from phone, or use factory one package?
Old 11-02-2016, 11:10   #3 (permalink)
Member: 1086393
Thanks Meter: 771
factory firmware downloaded from miui official forum.
Originally Posted by JayDi View Post
Hello.
Old 11-02-2016, 11:31   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks for info. Will find such sample in 1-2 days.
Old 11-02-2016, 11:35   #5 (permalink)
Member: 1086393
Thanks Meter: 771
ok, im waiting!
but it can't flash with spflash tool , can you please check this.
IMG TOO LARGE error.
Old 11-02-2016, 11:48   #6 (permalink)
JayDi's Avatar
Member: 462970
Tick "Firmware upgrade" and repeat flashing.
Old 11-02-2016, 12:44   #7 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 245
you try to search on MIUI thread
there is a tutorial how flashing with flashtool
Page generated in 0.22947 seconds with 8 queries
