Old 01-24-2017, 13:46   #1 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 407
Xiaomi Redmi 3s (land) account reset NOT DONE
Acc resetted, yes, but when phone have Internet connection, automatically blocks.
Forced Fix Repair, etc doesn't help. When phone goes online, phone is blocked.
Operation : Reset Settings [ v1.09 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 430 [MSM8937]
ID_BLOCK_S : 0077AC66
ID_BLOCK_I : 0004F0E1
ID_BLOCK_L : F8A12200ACBB6D30411BA5E074E61639
ID_BLOCK_L : 41BFB56CA38A9C520D9C35304FBF6B5E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0000C000/00100000/00001000/00001000
Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G32
Boot Ok!
MIAccount reset passed!
Normal reset :
> Select "FORCED FIX" or "REPAIR"  in FMT settings, press "Format FS / Reset Settings"
> PowerOn device and use. IF Device stuck on black screen with cable - use another FMT
> Not all devices supported yet! (tested on Hydrogen,Land,Redmi2)
Done!
Elapsed: 00:00:22
Old 01-24-2017, 14:45   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Downgrade to lover MIUI version.
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-24-2017, 14:49   #3 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 407
Where to find older flashes ?
Old 01-24-2017, 15:24   #4 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Which version u have in mble try with this file
http://bigota.d.miui.com/V7.5.8.0.MA...0b73f8c25c.tgz
The Following User Says Thank You to princesaddam For This Useful Post:
Old 01-25-2017, 10:22   #5 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 407
I have 8.0.3.0 ,Android 6.0.1 will try and report , thank you.
Old 01-25-2017, 10:55   #6 (permalink)
JayDi's Avatar
Member: 462970
8.x.x.x - have better protection.
Will try play with them soon.
Old 02-27-2017, 10:45   #7 (permalink)
Member: 1596
Thanks Meter: 12
I treid all versions and no success. It can only bypass account if no internet connection.
Old 02-27-2017, 11:02   #8 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Normal reset :
Done!
Elapsed: 00:00:22
have you a bootloader loocked or unloocked ?
if you have bootloader loocked you have no chance freind........
Old 03-22-2017, 14:43   #9 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
frp 6.0.1 is supported check
http://forum.gsmhosting.com/vbb/f296...index2576.html
Page generated in 0.17574 seconds with 8 queries
