04-08-2017, 11:21 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Xiaomi Redmi Hongmi Note 3 USER CODE RESET ??? Mediatek MT6795 Helio X10 cipset It has bootloader loked so VOLUME DOWN + POWER combination doesn't work (it enters directly on FASTBOOT mode) Found on other place a complicate tutorila to flash the phone, but I want a easy solution to reset this phone with Infinity. Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! |
04-08-2017, 11:50 | #2 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | another thing: after searching found that there are 2 version of this phone: Mediatek and Snapdragon , I thik that I have the second one: Xiaomi Redmi Note 3 - Full phone specifications can this be reseted with Infinity???? Card found : xxxxxxxx , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! |
04-08-2017, 12:45 | #3 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | Infinity platform detector dosen't recognize the phone: Connect device to USB cable while holding BOTH volume buttons! Connected device : Details : 0x2717 : 0x904D Vendor : No vendor info [NOT IN BASE] Mode : No mode info [NOT IN BASE] any sugestions of how to reset it????? |
04-08-2017, 13:46 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Need to connect phone in EDL mode, sometimes need to use edl cable or test point even. Br. Infinity Box Team. |
