Old 09-25-2017, 06:04   #1 (permalink)
Abul Basher's Avatar
Member: 1675107
Sonork: n/a
Thanks Meter: 120
xiaomi redmi note 4 pattern unlock not done
Operation : Reset UserLocks [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : 3D938BE4
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 7A27A4822A39EFB2C3952362F66494BB
ID_BLOCK_L : 5D9BD1708796B06E69F0111463DB077A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB
Boot Ok!
Error : FS verification fail! Encrypted or damaged!
Reconnect Power/Cable!
Old 09-25-2017, 06:34   #2 (permalink)
Member: 2043843
Thanks Meter: 39
Xiomi has encrypted FS ( file system)
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
I think Xiomi/redmi has encrypted FS so pattern lock and. User code can't be recover by flash mode .
Use format option to remove pattern or lock code.
Old 09-25-2017, 06:57   #3 (permalink)
Member: 1675107
Sonork: n/a
Thanks Meter: 120
but castomer need user data some importent file on phone
Old 09-25-2017, 07:34   #4 (permalink)
Member: 1675107
Sonork: n/a
Thanks Meter: 120
pattanlock reset done but user data goone
Old 09-25-2017, 10:37   #5 (permalink)
Member: 2043843
Thanks Meter: 39
next time search for TWRP
Search if your phone support TWRP recovery .. flash using CM2 snd boot into recovery and copy all data into SD card ( within TWRP)
but need extra time and skiill .. and maybe not all model supported bt you can give a try.
Old 09-25-2017, 10:45   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,002
It dead end. Encryption is not allow extract data and mount filesystem.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.23632 seconds with 7 queries
