04-08-2019, 14:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | xiaomi s2 ERROR : Loader send failed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 028C9367 ID_BLOCK_L : E7A0231FADA46C4F461AA6E175E1193E ID_BLOCK_L : 54A0DA79BC9FB76710EB281B64D21E43 Use CM2 Internal Loader FH_LOAD_CODE : 15 HINT : Check cable, connection and drivers! Reconnect Power/Cable! howto remove account on this device?? |
04-08-2019, 23:33 | #6 (permalink) | |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Quote:
after pickup new version from xiaomi ..y got this: Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 028C9367 ID_BLOCK_L : E7A0231FADA46C4F461AA6E175E1193E ID_BLOCK_L : 54A0DA79BC9FB76710EB281B64D21E43 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! Flash Chain : 60 Flashing now Flashing : config.bin ProgStart : ERROR: Only nop and sig tag can be recevied before authentication. Flash Error , Prepare data error #0 , Check battery charge! ERROR : Flashing failed! INFO : Check previous message for more info! Reconnect Power/Cable! ken flash and kent remove account br | |
04-09-2019, 01:30 | #7 (permalink) | |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 492 | Quote:
04-09-2019, 05:12 | #8 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,117 | @carlols32 Just download this and load into CM2 QLM and flash this file https://mega.nz/#!1TR0jYLb!zN0ip7FlN...p93laqDp4IzFrg |
04-09-2019, 08:41 | #9 (permalink) | |
after flash and turn wifi...acount comes again 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 028C9367 ID_BLOCK_L : E7A0231FADA46C4F461AA6E175E1193E ID_BLOCK_L : 54A0DA79BC9FB76710EB281B64D21E43 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x13 , VENDOR : NOT_IN_BASE , NAME : S0J9B7 Boot Ok! Flash Chain : 60 Flashing now Flashing : config.bin Flashing : persist.img Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:00:03 Reconnect Power/Cable! | |
04-09-2019, 10:52 | #10 (permalink) |
Member: 2211790 Status: Offline Thanks Meter: 5,117 | if after connect wifi come again then handset in lost mode 1) For permanent solution follow this link Xiaomi Mi Account remove (clean, lost) any model any country 2) For Temporary Solution remove account again without connect WI-FI enable oem and usb debugging from Developer Option.. then use these below commands it will disable app temporary... adb shell am set-debug-app -w --persistent com.xiaomi.finddevice adb shell settings get --user 0 global wait_for_debugger com.xiaomi.finddevice |
04-09-2019, 15:02 | #11 (permalink) | |
fone is not detect wed debuging and oem unlock...xiaomi make sound but nothing happens...itīs only detectable on fastboot or qualcom port. enable oem and usb debugging from Developer Option...will not work. br | |
