01-31-2018, 09:22
#1 (permalink)
Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331
Thanks Meter: 1,141 | XIOMI MI A1 repair imei PROBLEM Quote:
card found : 95d , v0136
infinity-box chinese miracle qualcomm module [qlm] v 1.16
operation : Write security [ v1.16 ]
1. Enable diaginterface on device [ by code, root or other way ]
2. Make sure diagdrivers installed and work correct
wait for phone...
Device found!
Initialize ...
Diagmode initialized!
Msmhw : 00000461
modhw : 0000100e
build : Mpss.ta.2.3.c1-00361-8953_gen_pack-1.117743.1.119183.2
rtime : Nov 7 201715:09:47
btime : Oct 10 201705:00:00
devst : 8953.gen
update imei[1] : 354567485634562
record update failed! Read-only! Security wipe required!
Update imei[2] : 354567485637771
Write done! Reboot device, if it not restart!
Hint : Qcn write and factory reset is required to finish process completely!
Done!
Elapsed: 00:00:03
reconnect power/cable!
Operation : Edl security operation [ v1.16 ]
1. Power off phone , remove battery , insert back
2. Press and hold both volume keys!
3. Insert usb cable. In some cases require use edl cable or tp to force edl mode!
Wait for phone...
Device found!
Initialize ...
Handshake passed!
Id_block_i : Snapdragon 625 [msm8953]
id_block_s : Ea6b465f
id_block_l : Ffb82b07b5bc64375e12bee97de91126
id_block_l : 35c3b918dffee8463188493c3bb37f22
use cm2 internal loader
loader sent! Initializing ...
Running firehose on bbid : Msm8953 , flash : Emmc , mver : 1
meminfo : 0x0003 / 0x0200 / 0x0000000e8f800000 [ emmc 64 gib ]
extinfo : 0x0001c000/00100000/00001000/00001000/00000200
storage : Mfr : 0x13 , vendor : Not_in_base , name : S0j9f8
boot ok!
Wipe security partitions
erase : Fsg
erase : Modemst1
erase : Modemst2
done!
Elapsed: 00:00:16
Operation : Write security [ v1.16 ]
wait for phone...
Device found!
Initialize ...
Msmhw : 00000461
modhw : 0000100e
devst : 8953.gen
Done!
Elapsed: 00:00:03
wait for phone...
Device found!
Initialize ...
Msmhw : 00000461
modhw : 0000100e
devst : 8953.gen
Done!
Elapsed: 00:00:03
wait for phone...
Device found!
Initialize ...
Msmhw : 00000461
modhw : 0000100e
devst : 8953.gen
Done!
Elapsed: 00:00:03
reconnect power/cable! | hi team can we fix such issue ? Phone wiped ok imei 0 in check but when i try fix imei its not work???? Any help pls |
