xoami redmi 3 i have xoami redmi 3 with patern lock i try to conect but not what problem is? 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! |
I have same problem I HAVE SAME PROBLEM.REDMI NOTE 3 NOT connecting |
First need reset power and then repeat connect operation. Also need select FW, because it CPU not supported yet. |
Operation : Reset Settings [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 0932F0E8 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 90631C1E3C904E88 ID_BLOCK_L : 1FB40806931E5BDF Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! where is FW select? |
In flashing tab. It allow work with not supported yet CPU's and models. |
