12-24-2015, 09:08 | #3 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Online Sonork: 100.1612198 Thanks Meter: 141 | Quote:
i flash with s003 version now handset is dead Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 45 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42017EE7DC5791DD DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42017EE7DC5791DD [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : XOLO ProdName : A500S_IPS ProdModel : A500S_IPS Device : A500S_IPS AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 EXTRA : LCD [0] : hx8379a_dsi_vdo_azet_ips LCD [1] : ili9806c_dsi_vdo_djn LCD [2] : ili9806c_dsi_vdo_qj LCD [3] : otm8018b_dsi_vdo_trust LCD [4] : otm8018b_dsi_vdo_djn LCD [5] : ili9806c_dsi_vdo_txd LCD [6] : ili9806c_dsi_vdo_azet_ips LCD Res : 800x480 TOUCH [0] : ft5206 TOUCH [1] : msg2133 CAM [0] : s5k5eayx_yuv CAM [1] : gc2035_yuv CAM [2] : gc0329_yuv MODEM : d208_c1a_hspa_gemini LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hdpi Done! Elapsed: 00:00:24 Reconnect Power/Cable! | |
12-24-2015, 10:09 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Post flashing log. Only version S003 and S0110 available. No any S005 version available. If you have backup then write it back and do SmartAV/App Manager with CM2MTK. You can also try to write only preloader file via Init Preloader and check phone. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
12-24-2015, 14:58 | #5 (permalink) | |
