05-09-2015, 11:07
#1 (permalink)
Member: 327043
Sonork: 100.1587811 Thanks Meter: 1,514 | Xolo A500s IPS Hang on logo Xolo A500s IPS Hang on logo
read file ok PHP Code: Wait for phone...
Phone found! [ 15 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004E35575A4D420190F6CC22B029
DA Stat : v4.2 on BBID : 0x88
DRAM not initializewd , configure DRAM Settings
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMZW5
[eMMC] : FLASH_CID : 1501004E35575A4D420190F6CC22B029
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
USBDL : Init HSUSB Ok!
Brand : XOLO
ProdName : A500S_IPS
ProdModel : A500S_IPS
Device : A500S_IPS
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
[Read Ok] : preloader_d208_lava_ips.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[Read Ok] : fat.img
[ScatCFG] : MT6572 / V1.1.1 / d208_lava_ips / EMMC
FW Size : 678 MiB
Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__XOLO__A500S_IPS__A500S_IPS__4.2.2__ALPS.JB3.MP.V1\
All done!
Done!
Elapsed: 00:10:44
Reconnect Power/Cable!
write file ok but verify error PHP Code: Scatter Load Ok , BaseBand : MT6572 , Project : d208_lava_ips , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.19 ]
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : d208_lava_ips , Storage : EMMC
Setting : AFF verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x00000000E5C80000
Flash Pre-Erase Done, time used : 00:00:08
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_d208_lava_ips.bin
Preloader Sent , Init passed
PartCount : 0013
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:01:04
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Error! Something went wrong!
ErrCode : 0x648F
Done!
Elapsed: 00:01:28
i not flash wit readed file
i not try og file because i afried if emmc damage then set gone dead
i want ask can u check all its emmc ok or not ??
can i try og firmware which i though risky ? |
