03-19-2019, 14:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | Xoro model TelePAD 10A3 mtk 6735 reset mdm ??? Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM14) MODE : BOOTROM PORT : 14 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 7001005631303031365019C8A3BAEE37 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 5600017031303031C819503637EEBAA3 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERROR : 000007D5 : BROM : CMD STARTCMD FAIL Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM14) MODE : BOOTROM PORT : 14 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 7001005631303031365019C8A3BAEE37 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 5600017031303031C819503637EEBAA3 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERROR : 000007D5 : BROM : CMD STARTCMD FAIL Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Product: alps Device Chipset: mt6735 Device Model: TelePAD10A3 4G Device Serial: XTPADL10A31GWB0621 Android Version: 6.0 Android SDK: 23 Architecture: arm64-v8a memo planer user and pass ? mdm ? reset ? |
