01-26-2009, 02:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Xtelcom X9118 mtk 6228 cannot formatt or flash help ==== log: [1/25/2009 2:48:40 PM] ==== COM5 [VCP0] selected module v2.74 Action: reset settings Model: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 33 sec Remove/Install battery now ! Unit not yet among supported list of infinity xtelcom maybe in next update you will include this unit. here's back up full flash: http://www.mediafire.com/?qnaimdzwqvh Any advice from Infinity help. Tia b.r. |
The Following User Says Thank You to kungpaoski For This Useful Post: |
01-27-2009, 02:05 | #3 (permalink) |
Member: 329609 Status: Offline Thanks Meter: 245 | here's logs for complete formatt: COM5 [VCP0] selected module v2.75 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading structure area... detecting structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: M600Z_B_PCB04_GPRS_MT6228_S02.00_0.BIN ver. sw 2: M600Z_B.00.0, 7EB15429 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[M600Z_B_PCB04_GPRS_MT6228_S02.00_0.BIN_D6AB4E81].rpl ==================== New firmware detected (v.2.75, database date: 21.12.2009): M600Z_B_PCB04_GPRS_MT6228_S02.00_0.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished Identification Done Write ... formatting... ........................error: code: 6600006900 ..error: code: 8C00006900 ....error: code: C800006900 .................................................. ....................error: code: A502000000 error: code: 0600000000 Write Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_27EADFDB_M600Z_B_PCB04_GPRS_MT6228_S02.0 0_0.BIN_D6AB4E81_20090127-090732.B4X.bin Finished, time used: 73 sec Remove/Install battery now ! have now 2 units with same problem here...hope to have solutiuon soon. tia b.r. |
01-27-2009, 14:26 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see there is a problems during format operation. In most cases it's not a software problem, but phone hardware problem, f.e. damaged or bad soldered flash chip. |
01-28-2009, 01:12 | #5 (permalink) | |
Member: 329609 Status: Offline Thanks Meter: 245 | Quote:
Ok Sir thanks for reply. But can you please include it in models selection list in next update. Tia. b.r. | |
2g 3.12 iphone cannot jailbreak or activate help | zaheerseria | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 01-18-2010 22:08 |
A411(DVGF3) cannot unlock or flash! | vanhh | UST Pro II | 5 | 06-09-2009 07:49 |
MTK 6228 CPU Problem : Need Help ??? | zeel_zeel | Infinity-Box | 3 | 06-10-2008 00:30 |
code unlock nokia 6103/or flash help! | leos72 | Nokia CDMA | 0 | 03-07-2007 14:56 |
Unlocking L7 SLVR (i-mode) on o2 Network without test point or flashing help? | sbud | Motorola P2k | 0 | 12-30-2006 20:36 |
