08-12-2008, 17:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Pak Age: 45
Member: 162328 Status: Offline Sonork: 100.1618216 Thanks Meter: 21 | Xtelecom X3128 two set DEAD HELP but they show problem cant read eeprom . plz help me hurry COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:15B4:9B9C high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: h:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8AA2844A.[E506_B16_PCB01_GPRS_MT6226_S01.00_1.BIN_E39F7A6A].rpl identification#1 detection finished device-id: 8AA2844A identification#1 protocol ver: 04 ver. sw1: E506_B16_PCB01_GPRS_MT6226_S01.00_1.BIN ver. sw2: E506_B16.00.1, 9585601C ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: h:\Program Files\InfinityBox\ChineseMiracle\system_log_8AA284 4A_E506_B16_PCB01_GPRS_MT6226_S01.00_1.BIN_E39F7A6 A_20080812-181713.B0X.bin Finished, time used: 59 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-14-2009, 22:47 | #5 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 961239 Status: Offline Thanks Meter: 8 | Quote:
your phone is china xtelecom 14speaker. first do safe format & ignore eeprom backup. if not successfull then download this model flash file from support erea & flash it with downloaded file. | |
02-14-2009, 22:54 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
unfortunately, we dont have such flash file in our collection. Can you share it with us? | |
02-15-2009, 17:08 | #7 (permalink) |
Freak Poster Join Date: Mar 2008 Location: tehran
Member: 719097 Status: Offline Sonork: 100.1613216 Thanks Meter: 32 | http://rapidshare.com/files/197976258/x100.rar.html this link for spaiderman file format we can use.......................tanks a lot for fars-gsm ΤεΡΗγ |
The Following 2 Users Say Thank You to farajzadeh For This Useful Post: |
i flashed lg b2060 ....after flash set dead..help. | Rin2 | Infinity-Box | 2 | 03-21-2010 06:01 |
nokia n95 reboot-did format ffs-after it set dead-help | zone2 | Infinity-Box | 1 | 05-14-2008 14:49 |
@AYMAN SHAMAYLH: XTelecom X3128 Flash Needed Urgent | yawarniazi | SpiderMan | 5 | 04-28-2008 08:21 |
Need on board pin-outs for Xtelecom x3128+ | zeerik | Infinity-Box | 10 | 03-10-2008 10:44 |
!!! Really nice working ...XteleCom... X3128 pinout... !!! | Faisal_Computer | Infinity-Box | 3 | 02-16-2008 16:13 |
