y336-u02 SPD7731g cant evenread info i got y336-u02 was bring from midleeast emergency calls only problem, was flash with my country flash file (B109) but still same, was try unlock but cant even check/read. i was open phone and check chip is SPD7731G Quote:
Did someone even read update logs? http://forum.gsmhosting.com/vbb/f296...oblem-2056515/ |
go to flash and click PAC then select Huawei_Y336_Y3C.sldr then i was try operation is there any thing else to do????? |
Rest things explained in my post already. Instead of SLDR you can select PAC file as well. But it will change nothing. Those phones are not locked by standard way. They customized via FW itself. So correct FW flashing should solve problem for some local carrier cases. |
ok bro ill try B108 and B110 rom and will report, and now i just try repair imei by service mode(use vol down) its work, but still emergency call only, as told will try that firmware. |
i was try flash with B108(on suport site) its fail then was try flash with B110 with infinity and research download tool given inside flash file both ways failed after FDL1 load but B109 flash without any problem but no network only emegency call, in netwok seting and sim settng menu all option hidden mode is any one can pls give NVM file from working phone to give try write NVM??????? |
pls help me , if boot loader unlock will flash any file????? |
Hm, strange. It should download well. Seems as FDL not compatible with this HW revision. |
