Old 03-31-2016, 17:59   #1 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 134
y336-u02 SPD7731g cant evenread info
i got y336-u02 was bring from midleeast emergency calls only problem, was flash with my country flash file (B109) but still same, was try unlock but cant even check/read.
i was open phone and check chip is SPD7731G
Card found: S/N : *****D8 , v0130
Chinese Miracle II [SPD module] v 1.16
SLDR Load Ok
BB CPU : SC7731
Huawei Y336-U02 (Y3C)
For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab!
Operation : Check/Read Info [ v1.16 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 39 ]
Port Opened
Sync...
Initial Boot Failed!
Reconnect Power/Cable!
3. Insert cable
Phone found! [ 39 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Old 03-31-2016, 18:06   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,695
Did someone even read update logs?
Huawei y336-u02 read problem
Old 03-31-2016, 18:07   #3 (permalink)
JayDi's Avatar
Member: 462970
Old 03-31-2016, 18:30   #4 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 134
i was select SP SC77xx[Model Select] then
go to flash and click PAC then select Huawei_Y336_Y3C.sldr
then i was try operation is there any thing else to do?????
Old 03-31-2016, 18:55   #5 (permalink)
JayDi's Avatar
Member: 462970
Rest things explained in my post already. Instead of SLDR you can select PAC file as well.
But it will change nothing. Those phones are not locked by standard way. They customized via FW itself. So correct FW flashing should solve problem for some local carrier cases.
Old 03-31-2016, 19:01   #6 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 134
ok bro ill try B108 and B110 rom and will report,
and now i just try repair imei by service mode(use vol down) its work, but still emergency call only, as told will try that firmware.
Old 04-01-2016, 06:23   #7 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 134
i was try flash with B108(on suport site) its fail
then was try flash with B110 with infinity and research download tool given inside flash file both ways failed after FDL1 load but B109 flash without any problem but no network only emegency call, in netwok seting and sim settng menu all option hidden mode
is any one can pls give NVM file from working phone to give try write NVM???????
Old 04-02-2016, 09:31   #8 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 134
bro is there any other way to change flash file in this phone?
pls help me , if boot loader unlock will flash any file?????
Old 04-02-2016, 11:26   #9 (permalink)
JayDi's Avatar
Member: 462970
Hm, strange. It should download well. Seems as FDL not compatible with this HW revision.
Page generated in 0.25612 seconds with 7 queries
