01-14-2016, 09:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | y360-u61 dead how can i fix this? . . Operation : HW Test [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034474530016C1E6E339289 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : 00000BBF Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! --------------------- Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034474530016C1E6E339289 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : 00000BBF Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! ----------------------- plz help thx |
01-14-2016, 12:45 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Chandpur U.P.West India
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | fORMAT ALL IN SP FLASH TOOL THEN FIRMWARE UPGRADE, IT'LL OK |
The Following User Says Thank You to farsi_007 For This Useful Post: |
01-14-2016, 13:32 | #6 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | infinity support models Y360-U61 Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D30344740F555C0B45291 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D30344740F555C0B45291 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Y360-U61 ProdModel : HUAWEI Y360-U61 Device : HWY360-U AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P43_1_wg_n EXTRA : LCD [0] : nt35512_wvga_dsi_vdo LCD [1] : hx8379c_wvga_dsi_vdo ili9806e_dsi_vdo LCD Res : 800x480 TOUCH [0] : GT1143 TOUCH [1] : MSG2138 TOUCH [2] : ft6336 CAM [0] : gc2355_mipi_raw CAM [1] : ov2680_mipi_raw CAM [2] : ov2680_mipi_raw_yiweili CAM [3] : ov5670_mipi_raw CAM [4] : hi551_mipi_raw CAM [5] : ov5670_mipi_raw_yiweili MODEM : wingtech82_wet_82kk_hspa_wt_pa_sky77590_band18_std _98360c1 LOCALE : es_US en_US zh_CN pt_BR es_ES pt_PT fr_FR de_DE ru_RU it_IT zh_HK zh_TW sv_SE nb_NO da_DK cs_CZ hu_HU sk_SK pl_PL ro_RO el_GR sr_RS mk_MK bg_BG fi_FI et_EE lv_LV lt_LT sl_SI hr_HR uk_UA tr_TR vi_VN in_ID ar_EG nl_NL th_TH ms_MY ca_ES hi_IN en_GB my_MM ko_KR bs_BA mk_MK fa_IR Done! Elapsed: 00:00:12 |
The Following User Says Thank You to GSM KPK For This Useful Post: |
01-14-2016, 14:22 | #7 (permalink) |
Member: 1876736 Status: Offline Thanks Meter: 735 | customer say after install app this happed . . i cant format with spflashtools or erase with cm2 i think its hardware problem thx anyway |
The Following User Says Thank You to sky73 For This Useful Post: |
10-23-2016, 12:45 | #8 (permalink) |
Freak Poster Join Date: Mar 2014 Location: swabi kpk
Member: 2139605 Status: Offline Thanks Meter: 31 | Y360-U61 Dead Invalid imei & Unknown Baseband repair 100000% solution Y360-U61 Dead Invalid imei & Unknown Baseband repair 100000% solution https://docs.google.com/uc?id=0B9XMa...xport=download Last edited by ziakpk; 10-23-2016 at 12:51. |
The Following User Says Thank You to ziakpk For This Useful Post: |
