Old 03-16-2016, 12:22   #1 (permalink)
Digital EDGE's Avatar
Member: 1240161
Thanks Meter: 159
Y541-U2 Emergency Calls Only After Unlock
The phone is GLOBE Ph locked and now, can't even use the original SIM.
Anyone of you with working NV, please share.
Old 03-16-2016, 12:51   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
IMEI inside is Ok now? BaseBand state?
Normally, for those phones, enough PAC flashing for unlock/repair.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-16-2016, 13:02   #3 (permalink)
Member: 1240161
Thanks Meter: 159
Originally Posted by JayDi View Post
Hello.
BB: OK
IMEI: Ok
And I tried to reflash with: Y541-U02V100R001C567B105
Old 03-16-2016, 13:07   #4 (permalink)
JayDi's Avatar
Member: 462970
Try reflash with factory flasher also.
CM2 by default not flash factory nvm for avoid calibration and etc damage.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 03-17-2016, 08:05   #5 (permalink)
Member: 1723271
Thanks Meter: 51
Possible change IMEI, in the philippines Globe and Smart are Blocking IMEI if there customer will not pay, including those MODEMS, ultera
The Following User Says Thank You to jryanp For This Useful Post:
Old 03-19-2016, 06:31   #6 (permalink)
Member: 1240161
Thanks Meter: 159
I only tried to reflash after unlock when I noticed that it loses signal even with the original SIM.
I tried it also.
Old 03-19-2016, 07:37   #7 (permalink)
JayDi's Avatar
Member: 462970
Loose signal?
Or not seen it at all?
What if you try read NVM from another one same phone and write to it, make factory resetand check?
Page generated in 0.17774 seconds with 9 queries
