-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Y620_u20 just vibrate after flash (http://forum.gsmhosting.com/vbb/f296/y620_u20-just-vibrate-after-flash-2154708/)
daddyunl0cker1 11-11-2016 23:10
Y620_u20 just vibrate after flash . Phone was have just pin lock .
i try with many versions but same but when i to make test its giving this error and please explain me about this error its mmc error or any other?
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A27481C177
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A27481C177
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0311512C6D10426C33C2CE0B409C0092
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Force eMMC test by user request
Processing Miscellaneous test
MSC : BatteryLevel : 3484 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040503A27481C177
[eMMC] : MODE : SQ-WR
[FAILED : READONLY] : eMMC state seems as READ-ONLY !!!!
Operation Failed
Elapsed: 00:01:02
Reconnect Power/Cable!
JayDi 11-11-2016 23:46
Hello. Because eMMC gone to ReadOnly due end of it resource - it not accept any FW and etc.
daddyunl0cker1 11-12-2016 19:15
can it alive boss ? ? ?
daddyunl0cker1 11-14-2016 21:09
any solution to alive this ??
daddyunl0cker1 11-21-2016 13:19
i have more 3 phones y520-u20 in same error can you help me ???
Kirumira 11-21-2016 13:38
Solution; Replace Emmc if you can.
Shensohau 11-21-2016 14:05
Hi, you don't need to replace emmc, if you flash wrong firmware on some mtk devices it will brick, for unbrick you need make testpoint, reflash with correct firmware and phone will be alive again... If EMMC is on good state by the way...
Best Regards
Shensohau
Page generated in 0.20261 seconds with 5 queries
