Old 11-11-2016, 23:10   #1 (permalink)
Member: 2384553
Thanks Meter: 75
Y620_u20 just vibrate after flash
Y620_u20 just vibrate after flash . Phone was have just pin lock .
i try with many versions but same but when i to make test its giving this error and please explain me about this error its mmc error or any other?
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A27481C177
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A27481C177
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0311512C6D10426C33C2CE0B409C0092
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Force eMMC test by user request
Processing Miscellaneous test
MSC : BatteryLevel : 3484 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040503A27481C177
[eMMC] : MODE : SQ-WR
[FAILED : READONLY] : eMMC state seems as READ-ONLY !!!!
Operation Failed
Elapsed: 00:01:02
Reconnect Power/Cable!
Old 11-11-2016, 23:46   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,002
Hello. Because eMMC gone to ReadOnly due end of it resource - it not accept any FW and etc.
Old 11-12-2016, 19:15   #3 (permalink)
Member: 2384553
Thanks Meter: 75
can it alive boss ? ? ?
Old 11-14-2016, 21:09   #4 (permalink)
Member: 2384553
Thanks Meter: 75
any solution to alive this ??
Old 11-21-2016, 13:19   #5 (permalink)
Member: 2384553
Thanks Meter: 75
i have more 3 phones y520-u20 in same error can you help me ???
Old 11-21-2016, 13:38   #6 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,355
Solution; Replace Emmc if you can.
Old 11-21-2016, 14:05   #7 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,801
Hi, you don't need to replace emmc, if you flash wrong firmware on some mtk devices it will brick, for unbrick you need make testpoint, reflash with correct firmware and phone will be alive again... If EMMC is on good state by the way...
Best Regards
Shensohau
The Following User Says Thank You to Shensohau For This Useful Post:
Page generated in 0.26673 seconds with 7 queries
