Old 06-29-2015, 08:18   #1 (permalink)
Member: 750118
Thanks Meter: 50
yelloboss n pradeep bro anybody plz help
mmx a59 spd 7710 imei reapir help needed
Start at : [6/29/2015 / 12:42:21 PM]
Operation : Read PatternLock [ v1.02 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 94 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3 @Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
ALWAYS HANG HERE
Old 06-29-2015, 08:21   #2 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,459
3. Insert cable
Phone found! [ 94 ]
Port Opened
Sync...
Sending FDL
ALWAYS HANG HERE
as Log Says - you are reading pattern?
The Following User Says Thank You to pradeep_kus For This Useful Post:
Old 06-29-2015, 08:24   #3 (permalink)
Member: 750118
Thanks Meter: 50
Start at : [6/29/2015 / 12:52:15 PM]
Operation : Repair Security [ v1.02 ]
2. Insert cable
Phone found! [ 94 ]
Port Opened
Sync...
Normal Mode init
Sync...
CHK THIS
Old 06-29-2015, 08:28   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,205
Hm...
Is there WAS ANY WORD about SC7710 in update log?
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-29-2015, 08:39   #5 (permalink)
JayDi's Avatar
Member: 462970
Just checked : With Service Cable + SC6531 selection you will able do repair IMEI well on SC7710/SC6820/SC8810.
Old 06-29-2015, 08:45   #6 (permalink)
Member: 750118
Thanks Meter: 50
mr JAY DEE
Originally Posted by jaydi View Post
just checked : With service cable + sc6531 selection you will able do repair imei well on sc7710/sc6820/sc8810.
cant solve by ur method still same
Old 06-29-2015, 08:53   #7 (permalink)
JayDi's Avatar
Member: 462970
That mean you do something wrong. Cable info in CM2SPD/docs folder.
Old 06-30-2015, 06:37   #8 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,608
hi,
plese post your read info log first and also check driver ......
Old 06-30-2015, 06:42   #9 (permalink)
Member: 750118
Thanks Meter: 50
Problem solved by fix nv file set dead
then full flash now set ok thanks to all but infinity hangs when i take info or do any operation although infinity is best box i ever have
Old 06-30-2015, 06:50   #10 (permalink)
JayDi's Avatar
Member: 462970
Because SC7710 is not supported yet.
Page generated in 0.31603 seconds with 7 queries
