01-25-2019, 10:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Yes LYF F10Q support in Cm2QLM thx to rebainoor Code: Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon Mobile 205 [MSM8905] ID_BLOCK_S : 0CFBBA85 ID_BLOCK_E : 00900000 ID_BLOCK_L : 62B7E5717A54628AB3DA3F08097ACBD9 ID_BLOCK_L : EFC83DCADBEF63887D866DFD019091BD Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : LYF ProdName : F10Q ProdModel : F10Q Device : F10Q AndroidVer: 6.0.1 Manufact. : QUALCOMM SysPatch : LYF-F10Q-000-01-20-100119 DevComTime: 10-Jan-19 12:54:18 PM QLMxCPU : MSM8909 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon Mobile 205 [MSM8905] ID_BLOCK_S : 0CFBBA85 ID_BLOCK_E : 00900000 ID_BLOCK_L : 62B7E5717A54628AB3DA3F08097ACBD9 ID_BLOCK_L : EFC83DCADBEF63887D866DFD019091BD Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : LYF ProdName : F10Q ProdModel : F10Q Device : F10Q AndroidVer: 6.0.1 Manufact. : QUALCOMM QLMxCPU : MSM8909 DevInfo : MSM8909__QUALCOMM__LYF__ANDR_v6.0.1__F10Q__F10Q__F10Q Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : usbdisk.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1401 MiB Done! Elapsed: 00:06:46 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon Mobile 205 [MSM8905] ID_BLOCK_S : 0CFBBA85 ID_BLOCK_E : 00900000 ID_BLOCK_L : 62B7E5717A54628AB3DA3F08097ACBD9 ID_BLOCK_L : EFC83DCADBEF63887D866DFD019091BD Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to sneha For This Useful Post: |
