10-08-2016, 09:07 | #1 (permalink) | |
No Life Poster Join Date: Apr 2007
Member: 485779 Status: Offline Thanks Meter: 135 | MT6582: Secure Flash Engine not working I try it Huawei G610-U20 Quote:
05-29-2017, 19:17 | #5 (permalink) |
Freak Poster Join Date: Mar 2007 Location: dz
Member: 463222 Status: Offline Thanks Meter: 29 | Dear Infinity Team, I didn't found the Imei section in security in CM2MTK Soft!!! this happened when i update my dongle last time to the version 1.36. what's the problem plz ?! |
05-29-2017, 19:41 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello,Run latest Dongle manager Go to "Serial number (S/N)Tab" set "UK Edition option off" Hit Process. ...done |
The Following User Says Thank You to Kirumira For This Useful Post: |
06-13-2017, 17:24 | #8 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Ayphone Technic
Member: 368730 Status: Offline Thanks Meter: 180 | VIVO Y15 IMEI NULL CAN'T REPAIR, NOT RESPONDING... Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530019C09C2F572C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530019C09C2F572C7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xF0BA2A240CE1CC1A0C11E1560CC632D9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 86XXXXXXX failed , record not exist or NVRAM damaged! Update IMEI[2] to : 86XXXXXXX failed , record not exist or NVRAM damaged! |
