10-16-2015, 17:09 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/Mediatek v1.34 - important improvements and fixes MTK SP/FP Platform - Flash Engine updated Improved MT6582 flashing Imrpoved MT6582/MT6572 DRAM init Improved HW compatibility check BatteryLevel check during flashing activated Some other changes and improvements - Smart AV engine updated - DeepScan improved - Detection revised, do not touch sensetive/system data on older platfroms - Revised Verification - Improved Virus removing Strongly reccomend to use latest version to avoid "hang" problem on some old phones! - UserData operations improved DataDirect: Improved support for SP and FP platforms - Firmware reading improved eMMC: Brand-specific improvements eMMC: Autodetection improved eMMC/NAND: Verification improved MT6795-specific improvements Supported Platforms for Factory FW Reading: MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6753/MT6795/MT87xx/MT83xx with eMMC MT625A/MT6260/MT6261 with SF/NOR MT6571/MT6572 with NAND - Other FlashID database updated InitPreloader operation improved Some bugfixes and improvements Official download link Infinity-Box 10 (ten) years (2005 - 2015) non-stop regular updates and support as nobody else - Infinity-Box - News Unlock Codes (Huawei, SE, Motorola, Samsung etc.), iPhone Unlock, Software Activations - Infinity-Box Online Service - Infinity-Box Dongle ready for delivery - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Telegram Last edited by YellowBoss; 10-16-2015 at 17:18. |
The Following 28 Users Say Thank You to YellowBoss For This Useful Post: |
10-16-2015, 17:24 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | ohhhh.. better... Smart AV engine updated - DeepScan improved - Detection revised, do not touch sensetive/system data on older platfroms - Revised Verification - Improved Virus removing Strongly reccomend to use latest version to avoid "hang" problem on some old phones! Yes is TRUE.. in some phones HANG in started...news and olds... But i hope that new version fix this option.. I tested and post!!!! Thanks for Nwe version..... KrazY_LaB. |
The Following User Says Thank You to maomatrix For This Useful Post: |
10-16-2015, 17:33 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan..
Member: 301242 Status: Offline Thanks Meter: 201 | I activate free version in my nokia infinity dongle woow great soft i like it now i am activating full version in my dongle great team i am using my infinity box 6 year with great in unloking and flashing . |
10-16-2015, 18:42 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Do as described in that link : After - download v1.34 from support area again. Not activated yet. | |
10-16-2015, 18:44 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @All : during flashing sw now shows battery level. It helps much, if after flash mobile is not poweron - check log and charge battery. Also, due low level device can disconnect in any moment of flashing. Code: ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3506 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x00000000A2764000 Flash Pre-Erase Done, time used : 00:00:06 |
The Following 9 Users Say Thank You to JayDi For This Useful Post: |
10-16-2015, 19:31 | #9 (permalink) |
Insane Poster Join Date: Nov 2012 Location: COLOMBIA
Member: 1842053 Status: Offline Thanks Meter: 30 | BLU Code: Operation : Read Flash [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0088 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! [Read Ok] : preloader_zechin71_e_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : fat_empty.img [Read Ok] : system.img [Read Ok] : cache_empty.img [Read Ok] : usrdata_empty.img [ScatCFG] : MT6571 / V1.1.1 / zechin71_e_lca / NAND FW Size : 205 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\chinos\MT6571__NAND__zechin71_e_lca Done! Last edited by bod; 10-21-2015 at 10:45. |
The Following 3 Users Say Thank You to Mr jhonson For This Useful Post: |
10-16-2015, 22:27 | #10 (permalink) |
Freak Poster Join Date: Jul 2013 Location: A Planet Called Earth Age: 34
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | Good work team please add user stop option in mtk n spd |
The Following User Says Thank You to server22 For This Useful Post: |
10-16-2015, 22:57 | #11 (permalink) |
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | Card found : S/N : 993xxxxx8 , v0129 Chinese Miracle II [MTK module] v 1.34 Code: Operation : Remove Viruses [SmartAV] [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420144F4C470517D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D420144F4C470517D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 55 Removing infected files and scripts ... SmartAV Report : Removed 55 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:24 Reconnect Power/Cable! Operation : Format FileSystem [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420144F4C470517D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D420144F4C470517D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! Last edited by bod; 10-21-2015 at 10:41. Reason: Code Tag |
10-17-2015, 05:01 | #12 (permalink) |
Banned Join Date: Mar 2010 Location: Okara Pakistan Age: 47
Member: 1273573 Status: Offline Sonork: 100.1623251 QQ.2905713135 Thanks Meter: 3,780 | Q Mobile S1 Read Pattern Done Q Mobile S1 Read Pattern Done Code: Chinese Miracle II [MTK module] v 1.34 Operation : Read PatternLock [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48384731650507E7A1A935622F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e1G8 [eMMC] : FLASH_CID : 90014A48384731650507E7A1A935622F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 5227 MiB Magic Ok Mount point : /data Get PatternLock ... ................................................. B.R JAMIL MOBILE |
The Following 2 Users Say Thank You to zulfqarali For This Useful Post: |
10-17-2015, 06:11 | #13 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | Still Not Read Factory File From mt6575 Still Not Read Factory File From mt6575 |
The Following User Says Thank You to asia_gsm For This Useful Post: |
10-17-2015, 06:29 | #14 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | Operation : Read Flash [ v1.34 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , [Micron] MT29C4G96MAZAPCJA_5IT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Too old device, FW reading not supported! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Last edited by bod; 10-21-2015 at 10:46. |
10-17-2015, 07:39 | #15 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Because already answered : http://forum.gsmhosting.com/vbb/f296...i8552-2002114/ Quote:
