Old 11-11-2016, 17:35   #1 (permalink)
Member: 1418143
Thanks Meter: 353
Thank buffer2k11 , SPD frp done
FRP removed , info all fine on my Windows 7 64 bits
thank you br buffer2k11
Chinese Miracle II [SPD module] v 1.22
Operation : Check/Read Info [ v1.22 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 14 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Reconnect Power/Cable!
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 14 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_14B_7731C_W16.12.2_Debug
Project : sc7731C_CP0_modem
HWInfo : sc7731C_CP0_modem
Compile : 03-11-2016 21:00:19
Phone Security Info :
IMEI [1] : 359869060275224
IMEI [2] : 359869060275232
BT_ADDR : 000000000000
SelfInfo :
BatVoltage : 3.779 V
Done
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Initial Boot Failed!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
3. Insert cable
Device boot not done
Check Drivers
Try again
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : X510
Model Brand : Infinix
Model Device: X510
AndrVersion : 5.1
BaseBand CPU: SP7731CEB
CompileDate : 5/16/2016 6:06:46 AM
Project Ver : VERSION_V06_20160516
Model Ext : X510
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:23
Operation : Format File System / Reset Settings [ v1.22 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:29
The Following 2 Users Say Thank You to psytr0nic For This Useful Post:
Old 11-11-2016, 17:47   #2 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 346
welcome @psytr0nic
The Following User Says Thank You to buffer2k11 For This Useful Post:
Old 11-11-2016, 17:54   #3 (permalink)
Member: 1418143
Thanks Meter: 353
pac read .
Operation : Read FullFlash [ v1.22 ]
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : X510
Model Device: X510
AndrVersion : 5.1
Model Ext : X510
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : oem.bin
[Read Ok] : sysinfo.bin
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1942 MiB
Saved to : x:\GSM\INFINITY\SP7731CEB_X510_5.1_VERSION_V06_201 60516_X510\
Done!
Elapsed: 00:15:32
The Following User Says Thank You to psytr0nic For This Useful Post:
Old 06-26-2017, 04:16   #4 (permalink)
Member: 2551676
please anyone with link to download x510 sc7731c?
Page generated in 0.16763 seconds with 9 queries
