05-05-2011, 17:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Pakistan Age: 36
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | Mt6253 Format Success But LCD Blank Now ??? 1 sim wasn't working before (sim 2 option was not showing in the fone) i did format it's done but fone lcd will not coming now what is this problem ??? Code: COM7 [VCP0] selected module v3.30 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: S516A_K050v01.00b05_Gright detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format... Disconnect... done Finished, time used: 1 min 13 sec Remove/Install battery now ! B.r., Sonu |
05-05-2011, 20:39 | #2 (permalink) |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | (When I Do Power On Fone Startup Sound And Fone Working But LCD Blank After Complete Format) Now I've Flash Fone With Full Flash Backup After Flash Now Fone Become Almost In Dead Condition (When I Hold & Press Power Button It Won't Power On If I Leave Power Button For a Second & Press Again Keypad Lights Will Be On & Display Nothing Or No Fone Start Up Sound Or Keypad Sound... What Is This Problem Please Help Me Urgent Infinity Team (I'll Upload Flash Backup Also Tomorrow) Please Check & Give Me Any Solution To Revive Fone Again B.r., Sonu |
05-06-2011, 08:36 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | You need to full flash the phone with good working firmware. Try to search for the required firmware on support area and flash the phone. Wr. |
05-06-2011, 09:04 | #4 (permalink) |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | How To Know Which Firmware Is Required For This Model Please Anybody Help Me Or Upload Any Firmware For Me Phone Model E100 Brand Cright |
05-06-2011, 09:25 | #5 (permalink) |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | Phone Brand Gright Phone Model E100 How Can i Search This Model File On Infinity Server .. ?? Need This Project ID File Urgent project-id: S516A_K050v01.00b05_Gright B.r., Sonu |
05-06-2011, 11:13 | #6 (permalink) |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | MT6253 After Format LCD Will Be Blank ..Help.. Infinty Team Please Give Me Some Advise Or Any Solution I have Recieved Fone Ok Before, Working Only With 1 Sim Sim 2 Option Wasn't Showing In The Fone I Did Complete Format Fone & Now Fone LCD Gone Again (Blank) What To Do Next ??? B.r., Sonu |
05-06-2011, 13:44 | #7 (permalink) |
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | Here Is The Complete Flash Backup Of This Fone Fone Was Working Ok With 1 Sim Only Before Complete Format Download B.r., Sonu |
05-06-2011, 16:33 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Flash file for this model is not present on support area. It would be good if someone posts same firmware from a working phone, the file will be prepared, converted and uploaded to support area for Infinity users. For the backup that you have posted wait for supporter to convert it and give you link. Wr. |
05-07-2011, 20:30 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! your flash file version is SIGNAL53_GEMINI_09A_SLIM_PCB01_GPRS_MT6253_S00.S51 6A_K050V01_00B05_GRIGHT.BIN_FLNPF38F3040M0Y3DF you must find same working phone and read out backup. or maybe you can find flash file somewhere. flash your phone, it must become alive |
6110 LCD Contrast Changing??? | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-14-2000 18:52 |
Plss help , I tried to change imei with wintesla on 5110 5.22 , now ... | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-11-2000 23:26 |
6110 unlocked but wont give reception | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-10-2000 22:15 |
