Old 09-06-2010, 16:54   #1 (permalink)
TECNICELL2007's Avatar
Member: 623464
Zonda 2000 dead after flash
after flashing this phone for unlock the respective
no longer lit, back with a phone firmware but do not turn on ................ any solution
regards
Old 09-06-2010, 17:11   #2 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
post here operation log.
The Following User Says Thank You to The_Dj For This Useful Post:
Old 09-06-2010, 17:16   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
regards
What MModule software version you have used ?
Old 09-06-2010, 17:43   #4 (permalink)
Member: 623464
COM4 [VCP0] selected
modulo v3.57
Servicio: Zonda-N2000
Checkeando datos, espere...
Action: write flash NAND
Escribir Firmware
Konka-D363_KONKA28_05C_PCB03_GPRS_MT6228_S02.KAA363_2_03 _207_2007-02-07_En_Cn.B4M.bin
saltar: Customization/Language Pack
saltar: Eeprom/ffs
firmware patch (sp-lock #1)...
not required
firmware patch (sp-lock #2)...
not required
nfi area detection...
external bootloader is not present
bootloader version: KONKA28_05C_BOOTLOADER_V005_MT6228_KAA363_2_03_207 .bin
nfi area detection (2 cores) finished: Ok
"formateo de ffs" activo
interface: BROM_DLL_v3.1016.00
Conectando...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
Connecting...
Booting...
Deje de presionar el boton power ahora !
bootcode current/expected: 3.2/3.2
CPU: 6228:8A02:8A02
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0007]: 00EC:00F100800015 [SAMSUNG] K9F1G08X0M
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
Listo
Set baudrate (460800)...
Listo
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: KAC363_MXA_SP_FR_EN_0.90.527
detect NAND info...
number of areas/bytes to read: 1:00080000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
bootloader version: D363MXC_BOOTLOADER_V005_MT6228_KAC363_MXA_SP_FR_EN _0_90_527.bin
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00020000
error: unexpected answer:
startup code area #1 is invalid
startup code area #1 detection done
rom info ver: 04
sw version: D363MXC_PCB03_GPRS_MT6228_S02.KAC363_MXA_SP_FR_EN_ 0_90_527.BIN
project-id: KAC363_MXA_SP_FR_EN_0.90.527, 7A641529
code offset: 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
===> Listo
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
number of cores: 2
loading files...
number of areas: 2
Listo
write...
write bootloader...
write core...
Format (HW_STORAGE_NAND)...
Disconnect...
Listo
Finalizado, tiempo usado: 12 min 54 sec
Quite/coloque la bateria ahora !
Old 09-06-2010, 17:58   #5 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
try write firmware_
Zonda-N2000_D363MXC_PCB03_GPRS_MT6228_S02.KAB363_MXA_SP_ FR_EN_0_90_B30_En_Fr_Es.B4M.bin
after flashed... repair security area
Old 09-06-2010, 18:05   #6 (permalink)
Member: 623464
try write firmware_
modulo v3.57
Escribir Firmware
Spice-S920_D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_ 90_617_64m_En.B4M.bin
saltar: Eeprom/ffs
not required
not required
bootloader version: D363SP_BOOTLOADER_V005_MT6228_KAB363_INA_EN_0_90_6 17.bin
Conectando...
Connecting...
Booting...
CPU: 6228:8A02:8A02
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
Listo
Listo
ram test...
testing...
ram test passed
detect ffs...
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
project-id: KAA363_2.03.207
detect NAND info...
TCL-ID detection...
rom info ver: 04
sw version: KONKA28_05C_PCB03_GPRS_MT6228_S02.KAA363_2_03_207. BIN
project-id: KAA363_2.03.207, 04812CC7
TCL-ID is absent
===> Listo
number of cores: 2
loading files...
number of areas: 2
Listo
write...
write bootloader...
write core...
Disconnect...
Listo
Finalizado, tiempo usado: 15 min 42 sec
Old 09-06-2010, 18:24   #7 (permalink)
Member: 623464
modulo v3.57
Escribir Firmware
Spice-S920_D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_ 90_617_En.B4M.bin
saltar: Eeprom/ffs
not required
not required
Conectando...
Connecting...
Booting...
CPU: 6228:8A02:8A02
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
Listo
Listo
ram test...
testing...
ram test passed
detect ffs...
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
project-id: KAB363_INA_EN_0.90.617
detect NAND info...
TCL-ID detection...
rom info ver: 04
sw version: D363SP_PCB03_GPRS_MT6228_S02.KAB363_INA_EN_0_90_61 7.BIN
project-id: KAB363_INA_EN_0.90.617, 2F423A8E
TCL-ID is absent
===> Listo
number of cores: 2
loading files...
number of areas: 2
Listo
write...
write bootloader...
write core...
Disconnect...
Listo
Finalizado, tiempo usado: 11 min 54 sec
Old 09-06-2010, 18:43   #8 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
try u repair security area ?
Old 09-06-2010, 19:31   #9 (permalink)
Member: 623464
COM3 [VCP0] selected
modulo v3.57
Action: repair security area
Flashear el telefono con una firmware del soporte !
Finalizado, tiempo usado: 0 sec
phone dead
Old 09-06-2010, 20:05   #10 (permalink)
Member: 130995
@TECNICELL2007
please, try to flash phone with original Zonda (but not Spice and Bird) files:
Zonda-N2000_D363MXC_PCB03_GPRS_MT6228_S02.KAC363_MXA_SP_ FR_EN_0_90_527_En_Fr_Es.B4M.bin
Old 09-06-2010, 20:29   #11 (permalink)
Member: 623464
Originally Posted by InfinitySupport View Post
@TECNICELL2007
do not work same thing happens
phone dead
Old 09-07-2010, 10:26   #12 (permalink)
YellowBoss's Avatar
Member: 1043909
Hello,
try to find FIRST operation log for this phone.
It is need to check FIRST operation log due to software read original firmware version.
I want to know original phone firmware version.
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.98433 seconds with 11 queries
