Old 03-09-2011, 14:59   #1 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
zonda zmtn615 sim blocked
unlock of zonda zmtn615 not working always sim blocked after any unlock option, and solution? tnx
COM13 [VCP0] selected
module v3.75
Device: Zonda-ZMTN615
Checking data, wait...
Action: "sp-unlock"
unlock method: standard fast
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:B7EC:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFF0026:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.75, database date: 12.02.2011):
TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.T201B_C W_0_03.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.T201B_C W_0_03.BIN
project-id: T201B_CW_0.03, 00000000
code offset: 00000000
ffs offset/size [01]: 00A00000/005F0000
TCL-ID is absent
ffs/eeprom address assigned: 00A00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
error: area 1 can not apply patch
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 1 min 35 sec
Remove/Install battery now !
Old 03-09-2011, 15:46   #2 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
also try flash with telcel bin from support but still cannot unlock, always " sim blocked "
now also blocked with original sim
Old 03-09-2011, 16:02   #3 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
flash back original backup and original sim accepted again but others state sim blocked
Old 03-09-2011, 16:43   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Download and install latest MModule 3.79 and then try again, also you can try with "smart fast" process.
Wr.
Old 03-09-2011, 17:24   #5 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
tried all spunlock ways also format and repair but still "sim blocked" next is v3.79 , tnx
Old 03-09-2011, 22:15   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Please, make one more test if possible, and try to read unlock codes.
What is the results ?
Also for sure we will double check this phone firmware for unlock possibility.
Old 03-09-2011, 22:50   #7 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
I did read unlock codes and got 12345678 see log:
module v3.75
Action: read unlock codes
unlock method: read codes
Model: Zonda-ZMTN615
19200 autodetect
CPU: MT6223
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: T201B_CW_0.03
Version: TINNO23C_08A_GEMINI_HW
80 byte(s) read
imei: 35563303062557
connection Ok
186 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 0000
174 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 12345678
lock[2] code: + 56781234
lock[3] code: + 1122
lock[4] code: - 3344
lock[5] code: - 5566
lock[6] code: + 7788
lock[7] code: + 9900
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 18 sec
The Following User Says Thank You to mrfixit For This Useful Post:
Old 06-13-2011, 21:54   #8 (permalink)
djkiddrick's Avatar
Member: 645603
Thanks Meter: 89
who have the pinout??
Old 11-05-2011, 23:24   #9 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 616
soloution is here
make full flash backup & eerpom ffs backup , for emergency
full erase whole flash chip
flash with
Zonda-ZMTN615_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00 .T201B_CW_0_03_2010-09-06_En_Es.B0M
tick , format ffs , unlock during flash
solution tested 100 %
enjoy
The Following User Says Thank You to rogerboogie For This Useful Post:
Old 07-05-2013, 20:37   #10 (permalink)
Member: 533695
Thanks Meter: 5
Perfect solution. Work 100%
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.22477 seconds with 9 queries
