11-26-2010, 03:03 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Zonda-ZMUR300 error unlocking. Im tried Zonda ZMUR300 unlock whit infinity but cant be done: First backup ffs = done without problem. Code: [Infinity Box] MModule v3.65 smart-card: connected S/N: XDXD:XDXD Wait... Device: Zonda-ZMUR300 Done ==== [23/11/2010 13:26:47] ==== COM6 [VCP0] selected module v3.65 Device: Zonda-ZMUR300 Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60.BIN project-id: MAUI.06B.W07.12.MP.V60, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Zonda-ZMUR300_UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60__ffs... file saved: D:\CELULAR\cajas\infinity\flash files\zonda\Zonda-ZMUR300_UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60__f fs_20101123-133009.B0E.bin Finished, time used: 3 min 26 sec Remove/Install battery now ! Code: ==== [23/11/2010 13:30:34] ==== COM6 [VCP0] selected module v3.65 Action: "sp-unlock" unlock method: smart fast Model: Zonda-ZMUR300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.1 Version: MAUI.06B.W07.12.MP.V60 Version: SPRING25_06B_HW 44 byte(s) read imei: 35588702027747 connection Ok 156 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! Code: ==== [23/11/2010 13:31:52] ==== COM6 [VCP0] selected module v3.65 Device: Zonda-ZMUR300 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60.BIN project-id: MAUI.06B.W07.12.MP.V60, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 89890000040089:89890000000000 Backup required data Done ====> Patch required data ... ........................................... lock area found ........................................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... required data found flash: 89890000040089:89890000000000 flash: 89890000040089:89890000000000 Write: area 1 (pass 1) ................................................................ area 1 patch applied Ok Special operation Done ====> Write ... flash: 89890000040089:89890000000000 flash: 89890000040089:89890000000000 Write: lock-area-1 flash: 89890000040089:89890000000000 flash: 89890000040089:89890000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 56 sec Remove/Install battery now ! Code: ==== [23/11/2010 13:35:22] ==== COM6 [VCP0] selected module v3.65 Device: Zonda-ZMUR300 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60.BIN project-id: MAUI.06B.W07.12.MP.V60, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Zonda-ZMUR300_UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60__ffs... file saved: C:\Documents and Settings\USER\Escritorio\Zonda-ZMUR300_UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _12_MP_V60__ffs_20101123-133839.B0E.bin flash: 89890000040089:89890000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................................................................ error: area 1 can not apply patch Special operation Done ====> Write ... flash: 89890000040089:89890000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 4 min 33 sec Remove/Install battery now ! Code: smart-card: disconnected smart-card: connected WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [23/11/2010 13:42:15] ==== COM6 [VCP0] selected module v3.65 Action: reset settings ("format ffs") Model: Zonda-ZMUR300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.1 Version: MAUI.06B.W07.12.MP.V60 Version: SPRING25_06B_HW 44 byte(s) read imei: 35588702027747 connection Ok building list... done items to clear: 170 warning: wrong packet cs items cleared: 170 of 170 building list... done items remains: 0 Finished, time used: 38 sec Remove/Install battery now ! select unlock during flash, but locked anyway. Code: Loading file v.05... Zonda-ZMUR300_UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60_En_Es.B0M.bin loaded usb bootloader (file) is absent rom info ver: 04 sw version: UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60.BIN project-id: MAUI.06B.W07.12.MP.V60, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent firmware date/time: 2009-06-19 14-04 hw1: SPRING25_06B_HW hw2: UR5_01.04.23-TC ==== [23/11/2010 13:43:43] ==== COM6 [VCP0] selected module v3.65 Device: Zonda-ZMUR300 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Zonda-ZMUR300_UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60_En_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60.BIN project-id: MAUI.06B.W07.12.MP.V60, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (general #0)... done firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: 89890000040089:89890000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 0 sec Remove/Install battery now ! Code: ==== [23/11/2010 13:51:17] ==== COM6 [VCP0] selected module v3.65 Action: "repair imei" imei write method: mode-2 new imei: 355887020277472 Model: Zonda-ZMUR300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.1 Version: MAUI.06B.W07.12.MP.V60 Version: SPRING25_06B_HW 44 byte(s) read imei: 00000000000000 connection Ok 44 byte(s) read verification... verification done: 35588702027747 Finished, time used: 20 sec Remove/Install battery now ! Code: ==== [23/11/2010 13:53:12] ==== COM6 [VCP0] selected module v3.65 Device: Zonda-ZMUR300 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: UR5_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_MP_V60.BIN project-id: MAUI.06B.W07.12.MP.V60, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 89890000040089:89890000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 89890000040089:89890000000000 Finalization Done Finished, time used: 1 min 1 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Code: Imei 35588702027747 already was repaired: 23/11/2010-13:51:44 Continue with this imei ? ==== [23/11/2010 13:54:52] ==== COM6 [VCP0] selected module v3.65 Action: "repair imei" imei write method: mode-2 new imei: 355887020277472 Model: Zonda-ZMUR300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.1 Version: MAUI.06B.W07.12.MP.V60 Version: SPRING25_06B_HW 44 byte(s) read imei: 00000000000000 connection Ok 44 byte(s) read verification... verification done: 35588702027747 Finished, time used: 15 sec Remove/Install battery now ! Code: ==== [23/11/2010 14:07:13] ==== COM6 [VCP0] selected module v3.65 Action: "sp-unlock" unlock method: smart fast Model: Zonda-ZMUR300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B803:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.1 Version: MAUI.06B.W07.12.MP.V60 Version: SPRING25_06B_HW 44 byte(s) read imei: 35588702027747 connection Ok 156 byte(s) read reading data... reading data #4... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! please check error Thanks for help. |
The Following User Says Thank You to bananin For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
