12-06-2008, 11:48 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Zong 136 unlock module v1.57 Device: ZTE-A136, Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-static_20081206-150419.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-security_20081206-150420.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-complete_20081206-150427.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_lock-area_20081206-150433.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 38 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to Yasir Ali For This Useful Post: |
12-06-2008, 15:12 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Yasir Ali Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
zong 136 is supported why | X-TRA | FuriousGold | 5 | 01-09-2010 16:20 |
ZONG ZTE 136 unlock ok 100% | best_unlocking | Infinity-Box | 7 | 10-11-2009 16:35 |
Zong zte 136 unlock | best_unlocking | Infinity-Box | 3 | 02-01-2009 16:01 |
Zong zte 136 unlock 10000% | best_unlocking | Infinity-Box | 1 | 01-24-2009 18:10 |
zong 136 easy unlock by Infinity-Box | aleem26 | Infinity-Box | 0 | 11-25-2008 14:54 |
