08-06-2009, 07:16 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Zong A136 After unlock LIMITED SERVICE COM20 [VCP0] selected module v1.66 Device: Zong-A136 Checking data, wait... Action: unlock restore Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090804-181338.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090804-181339.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090804-181345.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090804-181359.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 64 sec Only Zong sim working well. Other sim service provider showing Limited Service. I have to flash all files from support area. i have to write also EEPROM file. I have to write backup of eeproms. But problem is same after flash and write eeprom and i have unlock. Where is solution? |
08-06-2009, 07:26 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | again flash the set with zong files (along with eeprom file) problem will be solved if u need files add to me [email protected] |
08-06-2009, 07:29 | #7 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | No need full flash just write eprom problem should be solve. Files already present at suport site long ago. but if still cant trace then use this link. http://rapidshare.com/files/264264385/ZONG.rar.html |
08-06-2009, 07:32 | #9 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skype:[email protected] Age: 38
Member: 469651 Status: Offline Sonork: 100.1584040 Thanks Meter: 115 | boos this fone is cplc block |
08-06-2009, 07:40 | #13 (permalink) | |
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote: use these files (also include good and tested EEPROM) | |
J750 samsung after unlock Limited service Solved !! | kmaxmax | UST Pro II | 3 | 08-12-2009 15:41 |
x490 after Unlocking limited service | sr8787 | Samsung Hardware Repair | 2 | 07-19-2009 17:19 |
e900 after unlock limited service >>> | Faisal_Computer | UST Pro II | 2 | 01-21-2009 14:45 |
e900 after unlock limited service >>> | Faisal_Computer | UST Pro II | 2 | 01-20-2009 11:46 |
Zong A136 Sucssfuly Unlocked | zeerik | Infinity-Box | 3 | 11-08-2008 20:35 |
