11-25-2008, 14:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Now In USA Rim database Age: 47
Member: 248178 Status: Offline Sonork: 100.1579207 Thanks Meter: 323 | Zong A136 Imei Repair Successfully COM3 [VCP0] selected module v1.57 Device: ZTE-A136, Zong-A136 Checking data, wait... Action: "repair imei" new imei: 356735xxxxxxxxx Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-static_20081125-181526.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-security_20081125-181527.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-complete_20081125-181529.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_imei-area_20081125-181535.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_lock-area_20081125-181538.B1E.bin backup critical area Done Check memory ... lock found imei found #1 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 38 sec Remove/Install battery now ! Finished |
The Following 8 Users Say Thank You to G i l l a n i For This Useful Post: |
11-25-2008, 14:53 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-25-2008, 14:58 | #3 (permalink) |
Member: 248178 Status: Offline Sonork: 100.1579207 Thanks Meter: 323 | Second thing is that now Zong A136 Direct Unlock with Pana01 v 1.57 ==== log: [11/25/2008 6:40:51 PM] ==== COM3 selected module v1.57 Device: ZTE-A136, Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-static_20081125-180408.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-security_20081125-180409.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_eeprom-complete_20081125-180416.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136, Zong-A136_lock-area_20081125-180422.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 37 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to G i l l a n i For This Useful Post: |
1100 IMEI Repair Successfully by MXkey | nabindra | Nokia Hardware & Hardware Repair | 6 | 05-18-2012 05:38 |
02 Nov 2008: LG-KP135, SFR-111, Bird-V5518+, ZTE-A136, Zong-A136 models supported | InfinitySupport | Infinity-Box | 36 | 06-21-2009 10:59 |
zong A136 successfully direct unlock | zeerik | Infinity-Box | 4 | 12-02-2008 10:13 |
B100 imei repair successful | TURNING POINT | HWK | 0 | 09-17-2008 10:10 |
ZTE A136 Imei Repair 100% Ok. | Kanwalgee | SAGEM JTAG UNLOCKER | 0 | 09-15-2008 08:28 |
