Zong-A136 unlock COM53 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090205-122840.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090205-122841.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090205-122848.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090205-122901.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
I am not telling here that i am the 1st. I am posting logs of unlock for Infinity Team because they says every unlock report help them for improvement. If I am posting wrong thing then why Infinity Team says thank every time i post the log. |
==== log: [2/8/2009 12:08:38 PM] ==== COM24 [VCP0] selected module v1.60 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: -TU-P108A2V1.0.0B03 VDF-P108A2B06-Tu-TU02 g3dBV2.0 7 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090208-120856.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090208-120857.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090208-120903.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090208-120916.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
COM9 [VCP3] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090205-171704.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090205-171705.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090205-171707.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090205-171711.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 26 sec Remove/Install battery now ! |
COM24 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090208-191037.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090208-191038.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090208-191044.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090208-191057.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
==== log: [2/11/2009 2:51:59 PM] ==== COM24 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090211-145218.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090211-145219.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090211-145225.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090211-145238.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 52 sec Remove/Install battery now ! |
COM3 [VCP0] selected module v1.60 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090211-173518.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090211-173519.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090211-173526.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090211-173539.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 52 sec Remove/Install battery now |
COM24 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090212-105511.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090212-105512.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090212-105520.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090212-105533.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 54 sec Remove/Install battery now ! |
You may proceed with your work. :D:D |
==== log: [2/12/2009 4:36:09 PM] ==== COM5 [VCP3] selected module v1.62 Device: Asiafone-AF501 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_eeprom-static_20090212-163624.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_eeprom-security_20090212-163625.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_eeprom-complete_20090212-163632.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_lock-area_20090212-163645.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 48 sec Remove/Install battery now ! |
COM24 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090214-110106.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090214-110108.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090214-110115.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090214-110129.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 55 sec Remove/Install battery now ! |
==== log: [2/14/2009 5:40:44 PM] ==== COM9 [VCP0] selected module v1.62 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090214-174058.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090214-174059.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090214-174100.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090214-174103.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 22 sec Remove/Install battery now ! |
COM24 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090221-144554.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090221-144555.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090221-144601.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090221-144614.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
