Old 02-05-2009, 08:33   #1 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Zong-A136 unlock
COM53 [VCP0] selected
module v1.61
Device: Zong-A136
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090205-122840.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090205-122841.B1E.bin
reading eeprom-complete...
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090205-122848.B1E.bin
reading additional data...
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090205-122901.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 51 sec
Remove/Install battery now !
The Following User Says Thank You to murtaza_nns For This Useful Post:
Old 02-05-2009, 08:39   #2 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
mate you are toooooooooooooooooooo late.
Old 02-08-2009, 08:18   #3 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
I am not telling here that i am the 1st. I am posting logs of unlock for Infinity Team because they says every unlock report help them for improvement. If I am posting wrong thing then why Infinity Team says thank every time i post the log.
Old 02-08-2009, 09:01   #4 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
==== log: [2/8/2009 12:08:38 PM] ====
COM24 [VCP0] selected
module v1.60
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: -TU-P108A2V1.0.0B03 VDF-P108A2B06-Tu-TU02 g3dBV2.0 7
Check hardware Done
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090208-120856.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090208-120857.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090208-120903.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090208-120916.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 02-08-2009, 09:33   #5 (permalink)
.::adnangsm::.'s Avatar
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
COM9 [VCP3] selected
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090205-171704.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg
error: can't load database v.11
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090205-171705.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090205-171707.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090205-171711.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 26 sec
The Following User Says Thank You to .::adnangsm::. For This Useful Post:
Old 02-08-2009, 15:13   #6 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090208-191037.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090208-191038.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090208-191044.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090208-191057.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 02-08-2009, 17:54   #7 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
i totally agree with you,
The Following User Says Thank You to khadim100 For This Useful Post:
Old 02-11-2009, 13:00   #8 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
==== log: [2/11/2009 2:51:59 PM] ====
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090211-145218.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090211-145219.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090211-145225.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090211-145238.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 52 sec
Old 02-11-2009, 13:17   #9 (permalink)
Member: 547967
Thanks Meter: 653
COM3 [VCP0] selected
module v1.60
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090211-173518.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090211-173519.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090211-173526.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090211-173539.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
The Following User Says Thank You to mujahid_ali For This Useful Post:
Old 02-12-2009, 06:56   #10 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090212-105511.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090212-105512.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090212-105520.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090212-105533.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 54 sec
Old 02-12-2009, 07:02   #11 (permalink)
Member: 209722
Thanks Meter: 818
i am not telling here that i am the 1st. I am posting logs of unlock for infinity team because they says every unlock report help them for improvement. If i am posting wrong thing then why infinity team says thank every time i post the log.
oh ic.
You may proceed with your work.
Old 02-12-2009, 12:40   #12 (permalink)
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
==== log: [2/12/2009 4:36:09 PM] ====
COM5 [VCP3] selected
module v1.62
Device: Asiafone-AF501
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_eeprom-static_20090212-163624.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_eeprom-security_20090212-163625.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_eeprom-complete_20090212-163632.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Asiafone-AF501_lock-area_20090212-163645.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 48 sec
Old 02-14-2009, 07:02   #13 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090214-110106.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090214-110108.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090214-110115.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090214-110129.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 55 sec
Old 02-14-2009, 13:48   #14 (permalink)
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
==== log: [2/14/2009 5:40:44 PM] ====
COM9 [VCP0] selected
module v1.62
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090214-174058.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090214-174059.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090214-174100.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090214-174103.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 22 sec
Old 02-21-2009, 10:50   #15 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090221-144554.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090221-144555.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090221-144601.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090221-144614.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Zong a136 unlock exe thewarismobiles FuriousGold 0 03-27-2010 13:30
02 Nov 2008: LG-KP135, SFR-111, Bird-V5518+, ZTE-A136, Zong-A136 models supported InfinitySupport Infinity-Box 36 06-21-2009 10:59
''""::another zong a136 unlock thanks u infinty team''"":: ehsas_ghum Infinity-Box 0 04-23-2009 09:47
Zong-A136 unlock 100% .::adnangsm::. Infinity-Box 3 02-12-2009 20:49
ZTE-A136,Zong-A136 unlock MALIKtelecom Infinity-Box 1 12-18-2008 19:15
Page generated in 0.30709 seconds with 9 queries
