Old 05-06-2009, 17:48   #1 (permalink)
AYAZ42's Avatar
Member: 833620
Sonork: 100.1586892
Thanks Meter: 259
zong unlock sucsees
COM8 [VCP1] selected
module v1.65
Device: ZTE-A35
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090506-204240.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090506-204241.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090506-204242.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_lock-area_20090506-204246.B1E.bin
backup critical area Done
Check memory ...
error: unknown firmware, read flash and send to support
Check memory Failed
Finished, time used: 18 sec
Remove/Install battery now !
The Following User Says Thank You to AYAZ42 For This Useful Post:
Old 05-06-2009, 17:57   #2 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
old success many times users have post this anyway good its good 4 u
Old 05-06-2009, 20:41   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
module v1.65
Device: ZTE-A35
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Failed
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
w995 unlock sucsees apiruk SETool2 6 08-27-2009 01:33
............e65........... Unlock sucsees AYAZ42 Universalbox 2 07-31-2009 00:21
5310b unlock sucsees AYAZ42 Universalbox 1 06-24-2009 14:07
N 95 8 gb unlock sucsees AYAZ42 Universalbox 3 06-18-2009 13:57
j132 unlock sucsees...... AYAZ42 Infinity-Box 3 05-29-2009 22:57
Page generated in 0.22356 seconds with 8 queries
