02-05-2009, 11:31 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 44
Member: 889422 Status: Offline Thanks Meter: 182 | ZONG ZTE 136 unlock ok 100% COM5 [VCP0] selected module v1.61 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090205-130046.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090205-130047.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090205-130054.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090205-130107.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 52 sec Remove/Install battery now ! mushtaq best is pakistan |
The Following 6 Users Say Thank You to best_unlocking For This Useful Post: |
02-05-2009, 15:08 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
Zong Zte A316G+ unlock solution | Y2ksalman | Infinity-Box | 158 | 06-17-2013 08:01 |
Zong zte a316g+ unlocked usercode done | yasermalik | SAGEM JTAG UNLOCKER | 1 | 11-24-2009 06:25 |
Zong zte 136 unlock | best_unlocking | Infinity-Box | 3 | 02-01-2009 16:01 |
Zong zte 136 unlock 10000% | best_unlocking | Infinity-Box | 1 | 01-24-2009 18:10 |
